DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
external ceiling light
This topic originated from the How to page called Adding a new light and switch
Click here to return to the page called Adding a new light and switch.
  View previous topic :: View next topic
Author Message
kimbara
from United Kingdom
Thanked: 0 times
PostPosted: Wed Mar 07, 2007 9:54 am    Post Subject:
Reply with quote Thanks
I would be grateful for your advice. I want to connect an external ceiling light to my porch canopy. The electrical wiring coming from the house through the canopy consists of live, neutral and earth wires, together with a second and thicker earth wire. The connector box on the ceiling light has the following: labeled 'Mains Supply In': consisting of Earth, Neutral and Live connector boxes; and 'Switched Load Out': consisting of two live boxes labeled 'L' and 'L1'. The 'Mains Supply In' 'Live' connector box is already connected to the Switched Load Out 'L' connector box by a Factory fitted bridge wire. I should be grateful if you could advise me to which connection points in the ceiling light housing I should connect the live wire and the two 'earth' wires from my porch ceiling.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
sparkyspike
from United Kingdom
Thanked: 17 times
PostPosted: Wed Mar 07, 2007 7:08 pm    Post Subject:
It sounds like this is a light with a built in movement sensor. Do you want to use it as a fully automatic light? If so, wire the live into MAIN SUPPLY IN, the neutral into NEUTRAL and the earths into EARTH. Make sure you've identified the wires correctly and they are as you say. Was there a light there before? The L and L1 out are for additional lights if you need them.
Back to top
 Alert Moderators
kimbara
from United Kingdom
Thanked: 0 times
PostPosted: Wed Mar 07, 2007 7:19 pm    Post Subject:
Hi Sparky, I am most grateful for your reply. There was a light in place before, and I am now replacing it. You are right that it has a built in movement sensor, which has confused me a little because I would be quite happy with one controlled on/off by the internal wall switch in my hall. I was confused by the 'Switched Load Out' side of the connector housing, not having come across this before, and thought that perhaps I needed to connect the live wire to connector point L1 on this side. But I thank you for you advice to connect the live wire to the Main Supply In, and ignore the 'Switched Load Out' connectors. This is a single outside light and I do not intend adding any more additional outside lights through the connector housing. Thanks again.
Back to top
 Alert Moderators
sparkyspike
from United Kingdom
Thanked: 17 times
PostPosted: Wed Mar 07, 2007 7:40 pm    Post Subject:
You may still be able to use it as a manual light by using the lightswitch. Check the instructions. icon_biggrin.gif
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Fluorescent light and external PIR from 6amp MCB on con unit 4 400 Thu Nov 01, 2007 5:17 pm
external intruder light 3 400 Sun Mar 05, 2006 7:31 pm
External Light Wiring 2 1460 Mon Oct 29, 2007 6:04 pm
Twin external light 3 360 Sun Aug 12, 2007 9:55 am
External Light in the gate pillar 8 1480 Tue Mar 11, 2008 10:47 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
