DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
New Mixer & Rigid head
This topic originated from the How to page called Installing a shower
Click here to return to the page called Installing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Lar
from Ireland
Thanked: 0 times
PostPosted: Thu Mar 08, 2007 3:30 pm    Post Subject:
Reply with quote Thanks
Installing a new type recessed mixer unit and a rigid shower head . Any tips on fitting securly to stud walls .Pipes in place . Do i need a degree in gynocology ?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
TicklyT
from United Kingdom
Thanked: 20 times
PostPosted: Fri Mar 09, 2007 9:37 am    Post Subject:
Don't know about anyone else, but if the wall is to be tiled afterwards, I would think about cutting out a piece of plasterboard between two studs large enough to get at everything you need to.
Fit pieces of 12 or 18mm plywood between the studs to fix everything to.
Fit noggins around the edge of your hole in the wall.
When everything is tested replace the plasterboard, make good around it and prepare it for tiling.
Think about future access if anything goes wrong. For example could you create a 'trap door' in the other side of the wall if it backs onto , say, an airing cupboard?
Or keep back enough matching tiles to reinstate it later if need be.
__________________
If it isn't broken, keep fixing it until it is
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Worn mixer tap head 6 280 Sun Feb 24, 2008 7:19 pm
Bath mixer taps with shower head attachment 6 960 Wed Mar 16, 2005 11:00 pm
Shower head /arm compatability with 3/4" BSP mixer outl 4 440 Sun Apr 19, 2009 10:26 pm
Mixer tap with pull out head 7 3580 Fri Mar 31, 2006 5:47 pm
Can you wall mount the shower head of a bath/shower mixer? 4 320 Sun Aug 17, 2008 9:13 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
