| Author |
Message |
TheBigMatt
Joined: 26 Feb 2007 Posts: 42 Location: Sussex, United Kingdom
Posted: Sat Mar 10, 2007 3:51 pm |
Hi All, (again!!!)
Can you tell me if an Internal Overflow is part of the cistern itself (cast into the ceramic) or a function of a particular type of Siphon??
I have purchased a bathroom suite, the cistern is close coupled with all the holes i expected for a conventional siphon/overflow.
In the bag with the Internals is a blanking plug for the overflow hole (the instructions say to use this if you have an internal overflow).
Should i assume that the fittings are "universal" and that my cistern will not support an internal overflow
OR
That the internals that came with the suite are a cheap conventional set that i could replace with a more expensive siphon that has an internal overflow, and that i can do away with the external overflow pipe??
Any advice appreciated.
Regards Matt |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
Lagerkhan
Joined: 25 Jan 2007 Posts: 127 Location: United Kingdom
| Back to top |
wonderb0y
Joined: 25 Jan 2007 Posts: 240 Location: United Kingdom Thanked: 1 time
Posted: Sat Mar 10, 2007 4:14 pm |
It's part of the syphon and if water overflows if goes back into the pan through the same way the water empties from the cistern.
cheap or not it could still have an internal overflow, you can usually tell by a large pipe in the middle of the syphon above the water mark.
and yup best thing since sliced bread |
| Back to top |
TheBigMatt
Thanks LagerKhan,
you just made me a happy man....now all i have to do is hope the blanking plug won't leak.........LOL |
| Back to top |
Softus
Joined: 21 Oct 2004 Posts: 19557 Location: United Kingdom Thanked: 8 times
| Back to top |
TheBigMatt
Posted: Sun Mar 11, 2007 10:12 am |
Larf!!!!!!!!
on a serious note, anyone recommend a particular brand/type??
Just so i can go to the Plumbers Merchants and not sound like a numpty to the man in the brown coat.....
Matt |
| Back to top |
jay1
Joined: 07 Jan 2007 Posts: 163 Location: London, United Kingdom Thanked: 4 times
Posted: Sun Mar 11, 2007 10:21 am |
OR
nope your cistern should support an internal overflow as all the above ppl have said,,and the internals that came with the suite shouldnt need to be changed unless it is faulty
i had the same sort of instruction on a close coupled w.c that i fitted but the internal overflow worked fine. |
| Back to top |
Softus
Posted: Sun Mar 11, 2007 1:57 pm |
Er, I was being serious.  |
| Back to top |
