The mixer tap that I have bought for the kitchen is limited to 5 bar water pressure. How can I measure what my pressure is and what can I fit to limit the feed to to the tap to 5 bars?
you need a pressure gauge, which is quite expensive...5 bar is quite strong i think. You can't do anything inexpensive to reduce pressure so if your pressure is higher than 5 bar its best just to get another tap. I wonder what would happen to your mixer tap if the pressure was too high
If the water pressure to your tap is to high you need a valve in the supply pipe, so that you can reduce the it. Cheapest, ball valve about £1.25.
It's aways a good idea to put these in whenever the chance appears, as you can isolate whatever you are working on without disruption to the rest of the house.
surely if it did need it you would want a pressure reducing valve, ( example not just a ball valve which will reduce flow) but in general consider your self lucky if you get 5 bar
