DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
washing machine connection leak
This topic originated from the How to page called Installing a washing machine
Click here to return to the page called Installing a washing machine.
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
  View previous topic :: View next topic
Author Message
ablebakerout
from United Kingdom
Thanked: 0 times
PostPosted: Mon Mar 12, 2007 2:08 pm    Post Subject:
Reply with quote Thanks
Hi, I have plumbed our washing machine in, draining to the spigot under the sink, and have 2 leaks in the drain hose connections. The leaks are a) where the old hose has been connected to a new hose to lengthen it (using a standard connection and jubilee clips each side), and b) from the non-return valve. I was advised not to use jubilee clips either side of the non-return valve as the ends of the valve are stepped and apparently jubilee clips won't secure the hose ends any further. It took a lot of effort to get the hose ends onto the valve as the fit is so tight, but the connections still leak. The valve itself is also leaking from its middle join - it is brand new. The leaks are lessening with time but still definitely there. Does anyone have any idea what could be wrong, and what I could do about it?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
washing machine waste connection 5 3620 Sun Feb 29, 2004 3:55 pm
washing machine connection 3 480 Sun Jul 29, 2007 2:33 pm
New washing machine - cold water inlet connection leaking 2 1680 Tue Jul 12, 2005 3:42 pm
Washing Machine connection 2 640 Thu Oct 20, 2005 10:36 am
Range cooker connection question 4 360 Mon Feb 26, 2007 11:46 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
