DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Vaillant ecomax pro 18e condensing boiler
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
bashersmith
from United Kingdom
Thanked: 0 times
PostPosted: Wed Mar 14, 2007 3:23 pm    Post Subject:
Reply with quote Thanks
Can someone please help me, i have drained down central heating system to repair leaking radiator. When i have refilled system boiler will not restart, fan runs for 2/3 seconds then F1 fault code comes up, in manual this code relates to ignition problem. Have done everything in manual but still no luck.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Wed Mar 14, 2007 5:08 pm    Post Subject:
Turn off power for three min and try again.
Are you quite sure the gas supply is connected and has not been turned off under the boiler or anywhere else ???
If not then I suspect that for some reason its giving a wrong code.
Its most likely to be associated with water flow/air in the system.
If the boiler was left powered with the system drained then its possible it has tried to start up and has tripped a manual o/h stat.
Tony
Back to top
 Alert Moderators
bashersmith
from United Kingdom
Thanked: 0 times
PostPosted: Wed Mar 14, 2007 5:41 pm    Post Subject:
Thanks for advice Tony, have tried turning off for 3 mins still no luck, i did shut boiler down before commencing work. When i advance heater timer central heating pump runs for a couple of seconds but then stops, fault code and red light then show on boiler control panel. Would trapped air in system cause boiler not to ignite? Have bled rads and there does not seem to be any trapped air in pipes. Any more advice would be appreciated, Thanks.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Wed Mar 14, 2007 6:15 pm    Post Subject:
Did you bleed the pump? Big screw in middle?
Is it making noises as if there is air in it when you listen with a screwdriver?
Is there an auto air vent? If so is the cap just loose?
Tony
Back to top
 Alert Moderators
bashersmith
from United Kingdom
Thanked: 0 times
PostPosted: Wed Mar 14, 2007 6:22 pm    Post Subject:
Have unscrewed large chrome screw on pump and water came out, cant listen for air as the pump literally spins for 3 seconds before stopping. There is air vent above pump which is secure. Really dont know what else to try as boiler was working perfectly well this morning.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Wed Mar 14, 2007 6:23 pm    Post Subject:
bashersmith wrote:
Have unscrewed large chrome screw on pump and water came out, there is air vent above pump which is secure. Really dont know what else to try as boiler was working perfectly well this morning.
What do you mean by "its secure" ????
Tony
Back to top
 Alert Moderators
scatmanjohn
from Colombia
Thanked: 4 times
PostPosted: Wed Mar 14, 2007 6:38 pm    Post Subject:
I take it you have pressed the reset button?
Back to top
 Alert Moderators
bashersmith
from United Kingdom
Thanked: 0 times
PostPosted: Wed Mar 14, 2007 6:44 pm    Post Subject:
The cap seems to be fixed correctly and not just loose. Cap is about the size of your finger end, would this be cap we are talking about?
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Wed Mar 14, 2007 6:47 pm    Post Subject:
Back to top
 Alert Moderators
bashersmith
from United Kingdom
Thanked: 0 times
PostPosted: Wed Mar 14, 2007 6:48 pm    Post Subject:
In reply to Scatman there seems to be no reset button on this boiler, manual says to reset by switching off for 5 seconds then switching back on. Have tried this numerous times and have left for longer periods.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Wed Mar 14, 2007 6:50 pm    Post Subject:
Back to top
 Alert Moderators
scatmanjohn
from Colombia
Thanked: 4 times
I thought there was a little grey button with a picture of a flame on it?
Or am i mistaken?
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Wed Mar 14, 2007 6:53 pm    Post Subject:
Or am i mistaken?
I think you are thinking of the Ecomax range and not the Ecomax Pro, but youv'e made me doubt myself now icon_rolleyes.gif
Back to top
 Alert Moderators
bashersmith
from United Kingdom
Thanked: 0 times
PostPosted: Wed Mar 14, 2007 6:56 pm    Post Subject:
Nothing on this boiler, only one sliding switch off and on,one mode button in middle and two buttons either side all other modes are displayed on the digital display.
Back to top
 Alert Moderators
scatmanjohn
from Colombia
Thanked: 4 times
PostPosted: Wed Mar 14, 2007 7:06 pm    Post Subject:
My mistake...thats the system boiler..looks like a Glowworm Hxi
I thought you were on about the ecomax combi
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
I have a Vaillant Ecomax 800 condensing boiler. 2 460 Sun Nov 02, 2008 10:18 am
Vaillant ECOmax 286E condensing combi boiler 2 1340 Sat Dec 17, 2005 11:16 am
replacing old boile with condensing vaillant ecomax 5 780 Wed May 11, 2005 3:42 pm
Valliant Ecomax 824E Condensing Combination Boiler 6 2080 Sat Feb 25, 2006 8:28 pm
Problems with Vaillant over Ecomax Pro 18E boiler 5 600 Tue Jan 22, 2008 9:27 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
