Worcester 24CDi High pressure
3 Mar 2007
Edinburgh
Hi, have read a few posts like this but will ask anyway just incase the problems a bit different.
My combi has worked perfect but over the last few weeks the pressure has been quite high (anything between 3.5bar - off the gauge) and the pipe outside my house has been dripping pretty much non stop. The combi has normally been serviced by scottish gas and i know the key isnt still attached to it because its lieing beside the combi. I noticed that it has also been dripping water from underneath :(
Would it be wise to try and release the pressure before i get a plumber to look at it. I dont want to do anymore damage to it.
Anybody any ideas please?
This will be the same problem as another post yesterday! The plate heat exchanger is leaking!
The part may be about £50 and would perhaps take about 1.2 hours to fit and test the boiler.
Tony
yeh thats it
arent scottish gas going to replace it for you? you dont want to mess with this boiler if you are an amateur...it bites back somewhat.
