DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Drayton Digistat RF1 & SCR
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
krisardley
from United Kingdom
PostPosted: Sun Mar 18, 2007 1:15 pm Reply with quote
I have an RF1 & SCR and the SCR constantly shows a red light, so i thought it might be the RF1 Thermostat as it says the warranty expired 05/04 on the back of it so i thought it had died, replaced with a new RF1 tried to get the SCR to handshake with RF1 as follows:
Turn all power off to SCR & remove batterys from RF1
Turn power on to SCR and then hold down button 1 and then button 2 together - red light goes out - still holding down these buttons push the batterys back into RF1 unit
Now if i understand it should now perform the handshake and match the two units up together but i still get the red light on the SCR !
Any one have any ideas what i have done wrong or is my SCR dead !!!
If it helps it was working all OK till about 1 week and the boiler is new fitted about 1 year ago i think - My new RF1 only has one battery draw as well.
Many Thanks
Back to top
 Alert Moderators
121164
from United Kingdom
Thanked: 2 times
PostPosted: Sun Mar 18, 2007 1:59 pm Reply with quote
to enter learn mode push the button marked 1 followed by 2 and hold both depressed together.The red led should flash for 2 seconds then go out signifying the scr is in learn mode. RELEASE BOTH BUTTONS.
The red and green leds should both now be on.
Take the digistat rf and hold it in sight of the scr no closer than a meter.
slide down right battery draw (are you sure you only have 1) remove the plastic strip and slide back into place.Repeat the same procedure with the left.
give it a try but dont forget to RELEASE BOTH BUTTONS before battery operation.
grum
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 787 times
Take the RF1 unit up to the SCR.
Remove batteries and wait until display disappears completley. Check batteries are good. set scr into discovery mode. Push batteries back in as M I's, I think it is left pair first then right pair. You do not have to hold buttons on scr to lock together. They should now lock themselves together automatically. Follow M I's thoroughly. If all this fails replace unit icon_wink.gif
Back to top
 Alert Moderators
121164
from United Kingdom
Thanked: 2 times
PostPosted: Sun Mar 18, 2007 2:50 pm Reply with quote
One more point
check you have got a new RF1 and not a digistat 1
the digistat 1 has 2 AA 1.5 batterys
the rfi has 4 AA 1.5 batterys
GRUM
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 787 times
PostPosted: Sun Mar 18, 2007 2:57 pm Reply with quote
All the ones I've fitted have been called the Digistat 1 and have 4 'AA' batteries 2 in each battery draw icon_confused.gif
Back to top
 Alert Moderators
121164
from United Kingdom
Thanked: 2 times
PostPosted: Sun Mar 18, 2007 3:01 pm Reply with quote
I agree with you, all the i fit are the same .
but if the op has dashed down to b&q and picked up a digistat 1 in a hurry he has got the wrong one, hence the 1 draw
the digista 1 is hard wired only
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 787 times
PostPosted: Sun Mar 18, 2007 3:13 pm Reply with quote
Back to top
 Alert Moderators
krisardley
from United Kingdom
PostPosted: Sun Mar 18, 2007 3:25 pm Reply with quote
Thanks guys making some progress now, yes your right dashed down B & Q and have brought the hard wired version which has one draw in it. So went back upto the scr unit and turned it off again. Then turned it on and held down one and then two the red led flashed very quickly for about 1 second and disappears, they green & red LED are both out. I release the two buttons and the red one comes on striaght away, the green one does not ?
Any other ideas
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 787 times
PostPosted: Sun Mar 18, 2007 3:32 pm Reply with quote
I think you have now missed the point! Hard wired version will not work at all with SCR. You MUST change it for the RF unit with 2 battery draws!
Back to top
 Alert Moderators
krisardley
from United Kingdom
PostPosted: Sun Mar 18, 2007 3:55 pm Reply with quote
Hi, yep see what your saying about the hard wired version have taken it back and got my money back already.
When you hold buttons one & two when you release it the red & green leds should be lit up to show it is ready for the handshake from the RF1 unit. When i do this i only get the red light to come on.
Do the scr have a battery backup on board that may have failed ?
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 787 times
PostPosted: Sun Mar 18, 2007 4:09 pm Reply with quote
Not that I know of.
When replacing your RF unit I think you will find that you can only purchase the complete package. If you could find the RF unit seperatly I wouldn't mind betting it would be priced unreasonably icon_rolleyes.gif
Back to top
 Alert Moderators
krisardley
from United Kingdom
PostPosted: Sun Mar 18, 2007 4:13 pm Reply with quote
Thanks for your help, been looking around on the net and found them at about 90 mark for transmitter and recieve so looks like a new one !!
many thanks for your help
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 787 times
PostPosted: Sun Mar 18, 2007 4:20 pm Reply with quote
use my e-mail link and I can tell you where they are 80 +VAT plus postage icon_wink.gif
Back to top
 Alert Moderators
gingercolin
from United Kingdom
PostPosted: Wed Nov 19, 2008 10:46 pm Reply with quote
Had the same problem, and found one of the batteries had leaked and had made the connection in the right tray dirty. Cleaned the metal connection in the tray, changed the battery, and it got it to handshake with the receiver! I will be taking back the other other rf1 one i had bought ready to replace it.
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 64 times
PostPosted: Thu Nov 20, 2008 12:38 am Reply with quote
Turn the power off at the mains then back on and you will have a red light on the receiver. Push button 2 and then 1 simultaineously. The red light will blink several times for about 2 secs. If it doesn't the receiver is shot. If it does push the right hand battery tray on the transmitter first then the left...no blinking, transmitter fault, if it blinks it works.............usually!!
Back to top
The following user says thank you to ollski for this useful post:
ironmike2012 (29 Jan 2010)
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Drayton Digistat +3RF to a Worcester R40HE Plus 2 380 Wed Nov 18, 2009 9:20 pm
Replacing Honeywell T6360B with Drayton Digistat +3 thermo 7 760 Mon Nov 23, 2009 1:45 pm
Drayton Digistat 3 7 260 Wed Nov 25, 2009 8:04 pm
Drayton Digistat +3 - Erratic operation 7 360 Sun Nov 08, 2009 10:09 pm
Replacing Drayton Digistat RF3? 3 520 Fri Oct 30, 2009 10:55 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
