DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Skimming over old plaster
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
WaveyDave
from United Kingdom
PostPosted: Mon Mar 19, 2007 10:16 am Reply with quote
Hi
Builder I'm thinking of employing has told me his plasterers don't like skimming over old plaster. I've got to strip wallpaper from some walls, and I want to just have a painted wall. I expect that when I've stripped the paper, I'm not going to have a decent enough surface to paint.
Is there a reason, assuming the plaster isn't hollow/blown, that it can't just be patched/skimmed?
Cheers
Dave
Back to top
 Alert Moderators
AndyBill
from United Kingdom
PostPosted: Mon Mar 19, 2007 10:23 am Reply with quote
2 coats of PVA then skim over, i would.
your walls might be ok to just fill up and rub down when youve got the paper off.
Back to top
 Alert Moderators
summo
from United Kingdom
PostPosted: Mon Mar 19, 2007 12:30 pm Reply with quote
Sorry to hijack your question, but does the 2 coats of PVA also apply to plastering over a very battered painted wall?
It is well past the point of just filling and sanding, the previous owners must have moved shelves about a dozen times!
Back to top
 Alert Moderators
AndyBill
from United Kingdom
PostPosted: Mon Mar 19, 2007 1:30 pm Reply with quote
any bigger/deeper holes i would fill first , then 2 coats PVA , then skim
Back to top
 Alert Moderators
WaveyDave
from United Kingdom
PostPosted: Mon Mar 19, 2007 1:43 pm Reply with quote
Thanks for that.
What might be the reason for them refusing to skim it? Builder seems a very genuine guy and has been recommended by family, so I doubt he'd be trying it on. He said he can get plasterers to do it, but not his usual guys.
Back to top
 Alert Moderators
AndyBill
from United Kingdom
PostPosted: Mon Mar 19, 2007 1:48 pm Reply with quote
some plasterers wont skim over artex either,
maybe they believe that if you add moisture to the old plaster it could blow.
Fred Flinstone or Diyisfree will probably be able to help you more than me.
i just did a short plasterers course last week and one of the things we did was skim over previous plaster.
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1252 times
PostPosted: Mon Mar 19, 2007 4:34 pm Reply with quote
the main reason any spread does not like overskimming old plaster is the unpredictable nature of the existing product.
in other words it can crack like bu***ry!
the spread can do his best to prepare the wall with pva, use decent materials, apply 2/3 coats, trowel it up nice and smooth, only for the blessed finish to end up with hairline cracks everywhere, a couple of days later. icon_evil.gif
the same goes for artex. believe it or not, some artex finishes are applied to lining paper of all things! plasterers nightmare.
you just can't beat the predictability of boards and browning. icon_wink.gif
Back to top
 Alert Moderators
WaveyDave
from United Kingdom
PostPosted: Mon Mar 19, 2007 6:02 pm Reply with quote
The only thing is, I've been told the cost or replastering is likely to be 2-3 times the cost of just getting it skimmed icon_sad.gif
Thanks for the advice both.
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1252 times
PostPosted: Mon Mar 19, 2007 7:17 pm Reply with quote
in that case the onus is on you to decide wether you go for expensive/reliable or cheap/risky.
don't automatically expect to get cheap/reliable icon_wink.gif
Back to top
 Alert Moderators
WaveyDave
from United Kingdom
PostPosted: Mon Mar 19, 2007 7:21 pm Reply with quote
I take your point. TBH I'd already resigned myself to getting the whole lot plastered, until this weekend I was shown someone's house. Same age, they'd stripped the wallpaper and only had it skimmed, looked like a nice job. This is what prompted me to ask the question.
Thank for your help noseall. I think I'll strip the paper and see how the land lays.
Cheers
Dave
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1252 times
PostPosted: Mon Mar 19, 2007 7:28 pm Reply with quote
in the same breath, don't automatically expect cheap to be unreliable either. icon_wink.gif .
overskimming is about 70% reliable in my experience.
Back to top
 Alert Moderators
WaveyDave
from United Kingdom
PostPosted: Mon Mar 19, 2007 9:28 pm Reply with quote
So I'm guessing the spread will have an idea of whether it will work or not when he takes a look at the wall? Or is it just a gamble?
Back to top
 Alert Moderators
joe-90
from United Kingdom
Thanked: 857 times
PostPosted: Mon Mar 19, 2007 9:53 pm Reply with quote
It's all to do with the condition of the undercoat plaster. If you poke it with a screwdriver and it seems pretty firm - then PVA and skim.
If it just turns to powder when you poke it - then it has to come off.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Skimming over existing plaster 4 740 Fri Jul 21, 2006 6:55 am
skimming over existing plaster 5 1060 Thu Feb 08, 2007 6:32 pm
Re Skimming old plaster 7 620 Wed Aug 02, 2006 12:43 pm
skimming 4 560 Thu Feb 01, 2007 11:32 pm
Which finish for skimming? 10 1100 Sat Jan 13, 2007 12:42 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
