Joined: 19 Mar 2007 Posts: 4 Location: United Kingdom Thanked: 0 times
Posted: Mon Mar 19, 2007 5:46 pm Post Subject:
Outdoor Cabling
I currently have the following setup, outdoor double socket connected via a spur from indoor double socket.
I wish to install a 4 way outdoor switched box(for pond pump,lights, filter etc) but I also want to retain my outdoor double socket for use when gardening.
Can I install a 2-way outdoor junction box as a spur from the indoor socket and then connect the existing outdoor double socket and 4 way switch box to the new 2-way junction box?
I\\\'m not an electrician so any advise much appreciated!
Posted: Mon Mar 19, 2007 5:58 pm Post Subject:
The indoor socket is connected to my main consumer board which has a built in RCD. the existing outdoor socket is fully waterproof(IP56). I want to retain the outdoor socket but also add a waterproof 4 gang switched box for all my pond equipment. I currently have my pond equipment plugged into the outdoor socket but have to frequently change cables over when I need to use other equipment.
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Mon Mar 19, 2007 6:04 pm Post Subject:
So the spur is not fused? Then you can only put one socket on it (double socket is permitted) and nothing else.
You can either put an FCU indoors feeding the external socket, or take another spur off another convenient socket and have another outdoor socket. Anything on a spur that is not a socket (which therefore protects the load with a fused plug) needs an FCU with a fuse in it.
Posted: Mon Mar 19, 2007 6:27 pm Post Subject:
Firstly, many thanks for your info.
The 4 way box I am intending to fit alreadt contains a fuse, I was always under the impression that up to 2 spurs could be taken from a socket. Unfortunately I don't have another socket that's convenient to take another spur so I'm stuck with the existing indoor socket as my only power source.
In that case would the follwing be OK.
Indoor Socket to Fused Spur.
Fused Spur to Outdoor 2-way junction box.
Junction Box to waterproof double socket.
Junction Box to 4 way switched box(for pond equip).
Joined: 02 Jun 2005 Posts: 10887 Location: Cumbria, United Kingdom Thanked: 39 times
Posted: Sun Feb 08, 2009 5:09 pm Post Subject:
Don't know about the building regs saying anything like that, I'm pretty sure the IEE regs can be interpreted as saying something like you can only have one accessory per unfused spur.
Hopefully he will have sorted it by now though.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
