| Author |
Message |
Jumbouk
Joined: 20 Mar 2007 Posts: 2 Location: Kent, United Kingdom
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
sparkybird
Joined: 19 Jan 2005 Posts: 1118 Location: United Kingdom Thanked: 36 times
Posted: Tue Mar 20, 2007 5:28 pm |
Not that I know of, yet.
The ones you can dim (egmegaman) work by stage dimming - ie switch light on/off for stage 1, on/off again for stage 2 etc (4 stages in total). So you would only use your dimmer switch as a normal switch, ie switching it on/off.
I'm sure technology will catch up at some point though!
SB |
| Back to top |
Jumbouk
Posted: Tue Mar 20, 2007 6:17 pm |
Thank you SB. I hope technology does catch up before the EU has their way and get the normal tungstan bulb banned. In the mean time I will have to figure out another way to reduce the electricity comsumtion without losing too much light ... |
| Back to top |
sm1thson
Joined: 05 Sep 2005 Posts: 829 Location: Hull, United Kingdom
Posted: Tue Mar 20, 2007 8:25 pm |
whats an 'EEL bulb'? because you can get dimmable 'standard' CFL bulbs. |
| Back to top |
securespark
Joined: 11 Jan 2004 Posts: 22533 Location: Cheshire, United Kingdom Thanked: 306 times
Posted: Tue Mar 20, 2007 8:27 pm |
| sm1thson wrote: | | whats an 'EEL bulb'? |
Blimey. Don't you know that?
It's a new type of lamp made by Osram. Got an electric eel inside....  |
| Back to top |
casinojoe1
Joined: 11 Feb 2007 Posts: 24 Location: Manchester, United Kingdom
Posted: Tue Mar 20, 2007 8:45 pm |
| Back to top |
Steve
Joined: 15 Apr 2005 Posts: 15750 Location: Yorkshire, United Kingdom Thanked: 211 times
Posted: Tue Mar 20, 2007 9:18 pm |
| Jumbouk wrote: | | In the mean time I will have to figure out another way to reduce the electricity comsumtion without losing too much light ... |
Use CFL lamps, just less of them! Then you dont need a dimmer!
Honestly though, I have one of these and I am very impressed with it. I am waiting for the technology to be adapted into other energy saving lamps, then we'll all be happy! IMO, though, the technology employed in switch dimmable lamps is too cumbersome for general use. It takes too long to get used to it, and you have to teach everyone how to turn on a light!!  |
| Back to top |
breezer
Joined: 03 Jan 2003 Posts: 23330 Location: Sussex, United Kingdom Thanked: 24 times
Posted: Tue Mar 20, 2007 9:24 pm |
question then if i may
if its dimable form 100% down to 2% how do you actually dim it? |
| Back to top |
Steve
Posted: Tue Mar 20, 2007 9:27 pm |
erm . . . this lamp doesnt dim in stages, its constantly variable. Turn it on first time and its about 40%. turn it off and on, and it comes on 100%, then dims steadily to probably 2%, then back up. The level is set where you turn the switch off and on. |
| Back to top |
breezer
Posted: Tue Mar 20, 2007 10:27 pm |
ah, i see. thank you |
| Back to top |
