Fitting Single Oven against gas pipe
24 Apr 2005
Sussex
Probably another daft question from me but....
I'm fitting an Ikea kitchen in and have a gas hob and electric single oven. The gas pipe for the hob though sticks out 80-100 mm from the wall and most ovens have a depth of 545- 557mm to fit a 600mm cabinet, so the oven will stick out.
How are these usually fitted?
Should I get the gas pipe shortened so it's under the cabinet?
Any advice appriciated!
Alan
I assume you are talking about a built under oven. If you cant bring all the units forward & have a new worktop. What about having the gas pipe moved ie cut back & angled from behind the oven, so its to the side.
Have a look at the back of the oven as theses can be smaller than the front so it may go in with out moving the pipe
Thanks for the replys.
I haven't bought an oven yet so I'll try and get the smallest one possible.
There must be loads of kitchens out there with electric build under ovens with a gas hob on top and wondered where the gas pipe usually sits for these things?
Well usually I would keep it tight to the wall and then bend it near the top where it turns towards the hob,usually a bit tight but with a bit of measuring and jostling you can get it-you could even reduce down to 10mm copper for the last few inches if it makes it easier. ;)
