bob sedgewick
Joined: 24 Mar 2007 Posts: 3 Location: Bradford, United Kingdom Thanked: 0 times
Posted: Sat Mar 24, 2007 9:50 pm Post Subject: Radiator clanking |
I have a fairly old steel panel double convector radiator which has started to make an awful racket. The system runs off a Gloworm Spacesaver 45-60. This radiator does not have a TRV fitted. Am I right in thinking this noise is probably being caused by a piece of corroded loose debris? If so, can it be flushed out or is it time for a new rad? |
Agile
Joined: 26 Jun 2004 Posts: 24304 Location: London, United Kingdom Thanked: 192 times
Posted: Sun Mar 25, 2007 11:43 pm Post Subject: |
A rad is a passive thing with water flowing through it!
Its difficult to imagine what you problem is.
Usually its a TRV rattling but you dont have one!
Surely you can get an idea of where the noise is coming from?
Tony |
gas4you
Joined: 23 Feb 2007 Posts: 14312 Location: Norwich, United Kingdom Thanked: 41 times
Posted: Mon Mar 26, 2007 7:26 am Post Subject: |
If the noise is definitely coming from this old rad and I can't see why it should so suddenly, I would suggest taking it off and go out side and flush it through with a garden hose. Also check your rad valves for blockages.
This would be my first step. There's always a possibility that it is coming from somewhere else. have you had any alterations recently? __________________ Dave
DRL Gas Services |
bob sedgewick
