Nellasel
Joined: 25 Mar 2007 Posts: 3 Location: Bath, United Kingdom Thanked: 0 times
Posted: Sun Mar 25, 2007 11:25 am Post Subject: De-glazing existing unit |
I am swapping some obscure d/g panels for clear. I need to remove the obscure glass from an existing frame. What is the best method to remove the glazing beads from the inside of the d/g unit? |
Watchmaker
Joined: 29 May 2006 Posts: 225 Location: Leicestershire, United Kingdom Thanked: 0 times
Posted: Sun Mar 25, 2007 11:58 am Post Subject: |
Carefully insert a thin bladed knife into the gap where the angled glazing bar meets the window frame, at one of the corners, and give it a slight twist. You will find that the glazing bar will spring out of it's register and you will be able to lift the complete bar out. To re-fit the glazing bar, insert one end (with it's profiled locking section tucked into the frame) and tap, with a soft faced hammer, or a hammer and a block of wood, all the way along the bar. I find that a smear of liquid soap, on the locking profile, helps when re-fitting. Also, some light pressure, on the new DG panel, pressing it into the bedding foam tape, helps re-assembly. |
Nellasel
Posted: Sun Mar 25, 2007 12:51 pm Post Subject: |
Many thanks. I understood the principle ... but remained ignorant of the correct tools and approach. |
ryoc
Joined: 14 Apr 2006 Posts: 24 Location: Middlesex, United Kingdom Thanked: 0 times
Posted: Sun Apr 15, 2007 1:23 pm Post Subject: |
Sometimes you have to remove the rubber trim around the perimeter of the window on the inside. This make the unit loose in the frame, then you remove the outer beading. When you refit the unit, you push back in the inner rubber gasket, and this tightens the whole thing up again. |
Nellasel
