DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Using expanding filler Foam.
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Author Message
wolfboy
from United Kingdom
PostPosted: Mon Mar 26, 2007 11:04 am Reply with quote
I have a hole in a partition wall, where I cut space for pipework leading to a shower. The hole is about 2" deep and about 6" by 3ft. It will be difficult to repair with plaster board as there dosn't seem to be anything to fix the plasterboard to! The wall is filled with a kind of cardboard grid, but no wood.
I was wondering if I could use the expanding foam that comes in spray form.
1) Can I just spray onto pipe work direct (copper and speedfit), or should I protect/cover them first?
2) What sort of area is covered by the standard spray can size?
Regards
Wolfboy
Back to top
 Alert Moderators
Bon
from United Kingdom
Thanked: 10 times
PostPosted: Mon Mar 26, 2007 1:35 pm Reply with quote
I would always recommend sleeving pipework when travelling through any kind of wall as it gives peace of mind.
I'd also recommend using gloves when using the foam as it's a pain to get off your skin.
It's good stuff but really messy. If you're just doing the one penetration then one can will be plenty. If you can get a can that comes with a couple of nozzles as these usually block up with the foam that's left in them.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1511 times
PostPosted: Mon Mar 26, 2007 1:47 pm Reply with quote
You could fix some battens that you can fix plasterboard to, and if you want to, use expanding foam to give it overall support and rigidity. You could squirt it through holes in the board and fill the holes later.
I would probably sleeve the pipes with insulation just in case one day someone needs to get at them. If they are embedded in expanding foam it will be very hard.
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1326 times
PostPosted: Mon Mar 26, 2007 7:33 pm Reply with quote
if the cardboard honey comb backing is still there then cut a slice of plasterboard and dab it back into place with dry wall adhesive.
Back to top
 Alert Moderators
wolfboy
from United Kingdom
PostPosted: Mon Mar 26, 2007 8:34 pm Reply with quote
The plaster board at the back is only 9.5mm, so it will be difficult to fix batons without coming through the other side of the wall. I'm also limited for space as the gap is only just wider then the two pipes.
I will cover the pipes and try the squirty stuff.
Thanks for your help guys.
Wolfboy
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1326 times
PostPosted: Mon Mar 26, 2007 9:21 pm Reply with quote
..erm..hello. squirty stuff?
beleive it or not plaster products work very well with,..er.. plaster products. forget foam filling use good ole gypsum. icon_wink.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
removing dried expanding foam filler from hands 6 1240 Fri Dec 19, 2008 11:40 pm
The amazing expanding door! 3 460 Mon May 08, 2006 3:53 pm
Foam filler spray can 3 520 Mon Nov 09, 2009 11:08 am
Unibond Foam Filler 12 380 Mon Nov 08, 2010 8:16 am
Flexible foam sanding pads on architrave? 5 280 Wed Feb 16, 2011 10:41 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
