DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
decking on flat roof
This topic originated from the How to page called Flat Roof
Click here to return to the page called Flat Roof.
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
  View previous topic :: View next topic
Author Message
gardan47
from United Kingdom
Thanked: 0 times
PostPosted: Wed Mar 28, 2007 3:01 am    Post Subject:
Reply with quote Thanks
hi i am trying to find out if i can fit some decking on to my flat roof to make a balcony from the bedroom the roof was rebuilt 4 years ago with new boards and felt and seems still in good condition
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
daverik
from United Kingdom
Thanked: 0 times
PostPosted: Wed Mar 28, 2007 9:10 pm    Post Subject:
NO, not without spending a small fortune.
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 52 times
PostPosted: Wed Mar 28, 2007 9:12 pm    Post Subject:
Yes you can.
You need some propriatary spacers under the decking.
Do a google for ' promenade tiles ' and suppliers of the spacers should be listed
Back to top
 Alert Moderators
freddymercurystwin
from United Kingdom
Thanked: 41 times
PostPosted: Thu Mar 29, 2007 10:11 pm    Post Subject:
You need something like these; http://www.wallbarn.com/rubber-paving.htm
Are you going down the legal route? ie building regs, planning etc? No doubt you'll not want to hear this but your flat roof would have been designed as a flat roof whereas the potential loads on a balcony can be considerably more unless its only going to be tiny, still, thats a matter for your conscience!
Back to top
 Alert Moderators
kevnurse
from United Kingdom
Thanked: 3 times
PostPosted: Sat Mar 31, 2007 10:16 am    Post Subject:
The supporting structure for your decking can only be the walls supporting your roof. You cannot use any part of the roof to support the decking (unless you have a supporting wall under it). So, this means that you have to fit beams on top of the walls and then span the roof area between the beams with joists. The length of span will determine the thickness of the joists. This, in turn will determine the weight of the joists and the overall pressure that will pass down through the walls into the foundations. If its an old building, the additional weight of your deck might not be significant, because yars ago they made thick walls and big foundations, but new houses are built for purpose on an economy basis and they are not designed to take additional weight. Get an architect and structural engineer to give you some advice. It might cost you a few hundred quid, but its worth it.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
Decking a small flat roof 4 680 Sat Sep 01, 2007 4:04 pm
new decking on a flat roof 7 780 Sun Oct 23, 2005 4:59 pm
Decking on top of shed roof 5 720 Sun Mar 30, 2008 2:22 pm
Woodwool roof decking slabs? 4 500 Thu Oct 11, 2007 3:05 pm
ashphalt flat roof 2 300 Thu Jul 24, 2008 8:08 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
