HopelessofHinckley
Joined: 28 Mar 2007 Posts: 2 Location: Leicestershire, United Kingdom Thanked: 0 times
Posted: Wed Mar 28, 2007 12:18 pm Post Subject: Extractor fan - HELP Please |
I recently purchased a new build house (2003 ish) and the bathroom extractor fan has never worked. I\\\'ve checked the wiring and it all seems fine and now I\\\'m stuck for what else to try....has anyone got any suggestions for what else could be causnig the problem? Any help would be appreciated..... |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Wed Mar 28, 2007 12:24 pm Post Subject: |
If you have checked the wiring and there is voltage at the extractor terminals but the extractor does not work, buy a new extractor.
If there is no voltage there, look for an isolating switch (likely to be fairly high up, might be on the bathroom wall or over the door). It is most likely to be fed from the bathroom lighting circuit and to come on with the bathroom light.
If you have not already got one, buy a multimeter for £10 or less in the high street.
racket
Joined: 16 Apr 2004 Posts: 174 Location: Cheshire, United Kingdom Thanked: 0 times
HopelessofHinckley
Posted: Wed Mar 28, 2007 6:19 pm Post Subject: |
When I said I checked the wiring I meant I followed the projects guide on this website to check all the wires were in the right places and there were no loose connections. Cheers for the advice guys, I will pick up a multimeter at the weekend.
How do I check the resistance of the motor????? (Sorry but I'm no expert when it comes to electrics! - in case you hadn't guessed!!!) |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Wed Mar 28, 2007 6:20 pm Post Subject: |
read the instructins
but if its a new build is it not under any g'tee? __________________ Do you like music Mr Finch?
Forum = Opinions |
