DIYnot
Local | Network
   DIYnot > Forums
Local | Network
extra radiator problem
This topic originated from the How to page called Replacing a radiator
Click here to return to the page called Replacing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
adri123
from United Kingdom
PostPosted: Wed Mar 28, 2007 2:16 pm Reply with quote
Ive just fitted an extra radiator, i have taken the feed and return from existing rad pipes in the loft, the problem is that the radiator hardly gets warm, i have bled it and the system etc.
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 45 times
PostPosted: Wed Mar 28, 2007 2:41 pm Reply with quote
Do a search on Balancing
Back to top
 Alert Moderators
Fluffster
from United Kingdom
Thanked: 21 times
PostPosted: Wed Mar 28, 2007 2:42 pm Reply with quote
What type of system is it ? do you have a feed and expansion tank in the loft?
Have you tried increasing your pump speed?
Pete
Back to top
 Alert Moderators
adri123
from United Kingdom
PostPosted: Wed Mar 28, 2007 6:17 pm Reply with quote
Pete
Its a sealed system i.e with a combi boiler, i cant understand it because the other two radiators get as hot as they always did, the other is stone cold. I think I know how to adjust the pump speed, is it the large grooved disc on the end?
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 516 times
PostPosted: Wed Mar 28, 2007 6:18 pm Reply with quote
Try turning off all other rads and see if this will push water to it. May be an air lock in the pipework in the loft icon_wink.gif
Back to top
 Alert Moderators
adri123
from United Kingdom
PostPosted: Wed Mar 28, 2007 6:21 pm Reply with quote
Yes, sorry i forgot to say, if i turn the others off then it gets hot, it appears to be bled OK, however I can hear air in the pipes (only when the other rads are off though), i have used speedifit pipe by the way...
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 516 times
PostPosted: Wed Mar 28, 2007 6:25 pm Reply with quote
Have you got any air vents in the loft pipe work. You should have at least 2. If so have you bled via them?
Try taking rad off and put bucket over each rad valve in turn and opening valve to let water/air out etc.
Most combis will have the pump set to maximum anyway.
No it won't be the silver screw in the middle front. This is for bleeding the pump.
Back to top
 Alert Moderators
Timmyturtle
from United Kingdom
PostPosted: Wed Mar 28, 2007 8:14 pm Reply with quote
Sounds like air in the pipe still.
You will also need to balance the rads to give a little more bias to the new one
A couple of air bleeds would certainly help
Try running with only that rad on (from that circuit) for a while it may push the air out after a bit
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Adding an Extra Radiator 2 3220 Mon Dec 10, 2007 12:07 pm
extra radiator 3 300 Thu Jan 22, 2009 5:28 pm
Adding extra radiator to existing system 9 2280 Tue Dec 04, 2007 4:09 pm
Extra radiator 2 520 Wed Mar 19, 2008 11:21 am
Extra Radiator 8 1260 Sun Apr 16, 2006 6:30 pm
DIYnot
