Hi there, I had some water damage on my flooring which is a 3 strip engineered floor. This was caused by a leak in the en-suite shower and the wood floor near the ensuite got wet, it has now dried out but the top veneer has buckled at the edges, 1 strip was quite bad and I pulled it completedly off.
Unfortunately I did not see this as this part of the floor under a desk and also covered by a rug. The plywood base seems to be dry and fine now. The area of damage is less than a meter square so I dont want to replace the whole room.
Any ideas in the best way to fix this? Is it possible to buy just the veneer strips to replace? I don't want to replace a whole plank where only a section is damaged as these are 2m planks. The problem then being how to cleanly remove some strips which are still partly glued but buckled at the edges. I could try to wet the floor to the loosen the most of the glue on the strips I want to remove.
I have found a maple 3 strip flooring which seems to be a close match in terms of grain and colour. Is there a way to remove the veneer strip off new board to stick down onto the old plywood base?
The subfloor I think is suspended concrete as its a new build house. So if I needed to remove the plywood base as well would I use a circular saw set to the correct depth?
Any advice would be much appreciated. Cheers[/img]
Another idea, could I soften the veneer strips in water and then clamp them in a vice/workbentch to dry out flat to stick them down again? They are 3mm veneers. Or would this cause them to expand slightly?
I suspect if I try to remove any other strips the laquer at the edges would chip off, what would be the best way to reapply laquer for an even finish? thanks
