DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Filling loop wiki
This topic originated from the Wiki page called Filling loop
Click here to return to the page called Filling loop.
Post new topic   Reply to topic    DIYnot.com Forum Index > Wiki
  View previous topic :: View next topic
Author Message
oilman
from United Kingdom
Thanked: 7 times
PostPosted: Fri Mar 30, 2007 5:35 am    Post Subject:
Filling loop wiki
Reply with quote Thanks
The expansion vessel should be checked before restoring the system pressure. The expansion vessel has an air chamber separated by a rubber diaphragm. The air space is to allow space for the water to expand as it gets hotter, and the diaphragm keeps the air and water seperated. After a long time, air migrates through the diaphragm into the water. This means the expansion space gets smaller, and can disappear completely. Without the air space, the water pressure can increase until the pressure relief valve opens, providing it is not stuck.
To check the expansion vessel, you will need to find the pressure relief valve, usually found inside the boiler. The valve can be opened by twisting the top. Usually anti-clockwise, but some valves operate clockwise. Open the valve and allow the pressure gauge to fall to zero. Find the air valve on the expansion vessel. The valve looks like a car tyre valve. Momentarily press the centre pin on the valve, and check that air comes out. No air may come out, or water may come out. If water comes out, you will have to replace the expansion vessel.
Measure the air pressure using a tyre pressure gauge. The pressure can be set at 1 bar for most systems.
If the air pressure is low, you can pump it up using a car tyre pump. While pumping the air in, open the pressure relief valve so the water pressure stays at zero until the air in the vessel is at the correct pressure.
Then close the pressure relief valve and refill the water to the correct pressure, (around the same as the air pressure).
There is a chance the pressure relief valve will leak after this procedure, and will have to be replaced. This is unfortunate, but if the valve is not operated to check that it works, it could be stuck, and will not work when needed. If it does not work correctly, the expansion vessel could burst, leaving a lot of water in the wrong places.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
stevejac
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 30, 2007 6:26 am    Post Subject:
[quote]
Momentarily press the centre pin on the valve, and check that air comes out. No air may come out, or water may come out. If air comes out, you will have to replace the expansion vessel.
Is it not that if water comes out of the expansion vessel then the vessel will have to be changed icon_question.gif
Back to top
 Alert Moderators
Moderator 9
Moderator Comment
Posted: Wed Sep 26, 2007 12:25 pm    Comment:
Hi Stitch, I have sent your post here: http://www.diynot.com/forums/viewtopic.php?t=103532
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Wiki All times are GMT
Page 1 of 1
Jump to:
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
