Joined: 03 Apr 2004 Posts: 664 Location: United Kingdom Thanked: 7 times
Posted: Fri Apr 09, 2004 6:41 pm Post Subject:
There is usually a pre drilled hole in these types of sinks that has not been drilled all the wat through, you may a two depends which hand you want draining board, turn the sink upside down, you should see them, choose the one you wish to use a carefully tap it out with a small hammer, yes I said hammer
Joined: 24 Jul 2003 Posts: 18661 Location: London, United Kingdom Thanked: 62 times
Posted: Fri Apr 09, 2004 9:29 pm Post Subject:
I was taught to use a hammer and nail punch in the middle of the proposed orifice, from the top. Takes a while to get the position right, but always seems to work. Never tried it any other way!
Joined: 10 Apr 2004 Posts: 247 Location: United Kingdom Thanked: 0 times
Posted: Sat Apr 10, 2004 5:30 pm Post Subject:
Before starting to use any sort of hammer or punch, from the underside of the sink drill a smallish hole with a masonary drill (TURN OFF HAMMER ACTION) in the center (ish) of the recess.
Turn the sink over a taking SMALL amounts use a centre punch and hammer starting at the drilled hole working outwards. Do not hit too hard.
Joined: 28 Jun 2005 Posts: 7494 Location: United Kingdom Thanked: 31 times
Posted: Wed Mar 22, 2006 2:12 pm Post Subject:
Re: ceramic........
oldskool_plumbski wrote:
I Normally use a kango.and then fit a steel one. L.M.AO.
We use lead lined troughs, and I solder up the corners using my moleskins.But the moles are protected like bats now and the friggin` foreigners from Kent come and nick the lead
Joined: 17 Nov 2005 Posts: 293 Location: United Kingdom Thanked: 0 times
Posted: Wed Mar 22, 2006 9:00 pm Post Subject:
Re: ceramic........
I think the original poster has got it sorted by now. April 2004!!!!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
