DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Saunier Duval Xeon 60FF boiler won't run. Fan Hunting?
Goto page 1, 2, 3  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Jboy
from United Kingdom
PostPosted: Sun Apr 01, 2007 11:35 am Reply with quote
The boiler won't fire up, the flue fan just keeps stopping & starting. Followed Faulting guide & swapped Air pressure switch & control board, checked all piping, also swapped fan but no change. Any idea's? Also what is the Air pressure switch actually "looking" for? Positive pressure down the red pipe, vacuum up the clear? If I disconnect both pipes to the switch the fan will run constantly but the boiler still doesn't fire up.
Back to top
 Alert Moderators
Rob
from United Kingdom
Thanked: 399 times
PostPosted: Sun Apr 01, 2007 11:57 am Reply with quote
Is this your own boiler?
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 805 times
PostPosted: Sun Apr 01, 2007 12:03 pm Reply with quote
Have you connected aps pipes the correct way around? Try switching them to eliminate this.
Back to top
 Alert Moderators
nortimax
from United Kingdom
Thanked: 25 times
PostPosted: Sun Apr 01, 2007 12:08 pm Reply with quote
Does this boiler have a pilot or a flame rectification?
Back to top
 Alert Moderators
Jboy
from United Kingdom
PostPosted: Sun Apr 01, 2007 12:11 pm Reply with quote
Yup, it's my own boiler- worst luck. Pipes checked both have no leaks & red pipe confirmed goes from H on APS to near the output on the fan. If I swap them around on the APS the fan runs continuous but still no led3 or boiler firing up. Huge blast of air out the flue, no change of I block flue with my hand. Should I be able to start the boiler firing if I gently blow down the red pipe?
Back to top
 Alert Moderators
Jboy
from United Kingdom
PostPosted: Sun Apr 01, 2007 12:12 pm Reply with quote
Whats flame retrification? It has a pilot which automatically fires up normally.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 805 times
PostPosted: Sun Apr 01, 2007 12:16 pm Reply with quote
If it worked like this then it would prove fan/aps/pipe fault
Back to top
 Alert Moderators
nortimax
from United Kingdom
Thanked: 25 times
PostPosted: Sun Apr 01, 2007 12:17 pm Reply with quote
That could be your problem. no pilot no rectification no boiler!
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 805 times
PostPosted: Sun Apr 01, 2007 12:19 pm Reply with quote
As nortimax says. If no pilot and burner lighting then fan will keep stopping and starting each time the boiler tries to light. probably do this about 3-5 times then lock out. Is this what you are getting?
Back to top
 Alert Moderators
Jboy
from United Kingdom
PostPosted: Sun Apr 01, 2007 12:24 pm Reply with quote
If it worked like this then it would prove fan/aps/pipe fault[/quote]
Sorry I don't understand, it must be the cold! The PCB has 4 neons, only 1 & 2 are lighting. The faulting guide indicates an air flowing fault. If neon 3 was lit it suggestes ignition, pilot or flame problem. I've just checked the old APS & it seems to switch ok when I blow down the H connector. (Should have checked it before rather than take the guides word it was the fault!)
Back to top
 Alert Moderators
nortimax
from United Kingdom
Thanked: 25 times
PostPosted: Sun Apr 01, 2007 12:25 pm Reply with quote
You might have spent a lot of money for a blocked pilot injector. Rectification is (believe it or not) when you put an AC current to a flame. The flame carries the current changes it to DC and is picked up by the flame sensor. Simple and effective flame failure device.
Back to top
 Alert Moderators
Jboy
from United Kingdom
PostPosted: Sun Apr 01, 2007 12:26 pm Reply with quote
Just to add the fan goes for 1 second & stops for 1 sec etc.
Back to top
 Alert Moderators
nortimax
from United Kingdom
Thanked: 25 times
Thought you said you had replaced the pressure switch sorry.
Back to top
 Alert Moderators
Rob
from United Kingdom
Thanked: 399 times
PostPosted: Sun Apr 01, 2007 12:28 pm Reply with quote
fan cycling is usually the pcb, as soon as it recieves the N/O from the APS.
Back to top
 Alert Moderators
nortimax
from United Kingdom
Thanked: 25 times
PostPosted: Sun Apr 01, 2007 12:30 pm Reply with quote
jboys first post sates he's also changed the board.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 3
Jump to:
Saunier Duval Xeon 60ff: Getting it to Temperature 2 60 Sat Jan 19, 2013 6:39 pm
Saunier Duval Xeon Boiler - no pilot light (and no idea) 5 40 Wed Jan 18, 2012 6:14 pm
Hunting for boiler baffles 2 560 Wed Dec 23, 2009 6:44 pm
Halstead Ace High boiler hunting on HWS temperature....... 6 60 Sun Mar 18, 2012 1:06 pm
Stuart Turner Monsoon Universal 4 bar twin - HUNTING 196 5440 Thu Oct 06, 2011 12:21 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
