- Joined
- 11 Feb 2006
- Messages
- 44
- Reaction score
- 0
- Country
With the fusebox switched off, I was trying to pull a cable out through a wall, but tugged on the wrong one and tore it out the back of a single lightswitch!
To reconnect it, I have a red wire, a black wire and a bare wire with a green / yellow sleeve.
On the back of the switch, there is a connector at the top marked 'COM' and at the bottom there are two connectors, 'L1' and 'L2'.
I think red was connected to COM because there was a bit of red sleeve left behind. I'm guessing black goes to 'L1' or 'L2', but which one? I'm confused as to what to do with green / yellow because diagrams suggest it should be connected to some metal in the wall mount, but the wall mount is all plastic!?!?!
Thanks in advance.
Thanks in advance.
