DIYnot
Local | Network
   DIYnot > Forums
Local | Network
SWA Cable connecting to normal flex via junction box
Author Message
widgles
from United Kingdom
PostPosted: Tue Apr 03, 2007 1:24 pm Reply with quote
I'm not electrical minded I am ony ask on behalf of someone without computer access.
As the title say we need to connect the SWA cable to normal flex & plus via junction box so the power runs through (as you can't put a plug on SWA)
SWA cable has 3 wires : Brown, Black & Grey
Flex: Brown, Blue and Gwn/Yw
I've tried to look up the wire colours on the computer but have got confused looking at the new regulations colours etc
We understand the colour on the normal flex (Live, Neutral & Earth) but what are they on the SWA? (we have earthed the SWA cable using the correct Glands)
Any advice would be much appreciated.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 415 times
PostPosted: Tue Apr 03, 2007 1:37 pm Reply with quote
Are you entirely sure you know what you are doing? I take it by using SWA it is going underground outside? Are you aware of part P of the building regs? I don't mean to put you down, just that if not done correctly, this can be very dangerous.
Back to top
 Alert Moderators
sm1thson
from United Kingdom
PostPosted: Tue Apr 03, 2007 1:40 pm Reply with quote
SWA-Junction box-Flex-Plug
something doesnt sound right, can you explain more what you are doing and why?
Back to top
 Alert Moderators
widgles
from United Kingdom
PostPosted: Tue Apr 03, 2007 1:43 pm Reply with quote
It's not me doing it I'm just writing the text.
Yes - it is going outside underground it is for a pond filter/pump going into switchbox.
Part P: Yes, they will be notifying the relevant people before any works are done.
The person doing the electrics are very competent, but has not worked with the SWA cable for along time and would rather check things are correct before going ahead with anything.
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 1095 times
PostPosted: Tue Apr 03, 2007 2:28 pm Reply with quote
widgles wrote:
The person doing the electrics are very competent, .
And so competent that they do not know about harmonized cable colours ? icon_rolleyes.gif
TTC
Back to top
 Alert Moderators
sm1thson
from United Kingdom
PostPosted: Tue Apr 03, 2007 2:39 pm Reply with quote
quite rightly so as you dont put plugs on fixed installations!!!
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 415 times
PostPosted: Tue Apr 03, 2007 4:48 pm Reply with quote
It is sounding similar to one of those armadillo kits.
The colour scheme which has been adopted by most is:
Brown - Phase
Black with green+yellow sleeve - Earth
Grey with blue sleeve - Neutral.
As you say, the armour of the cable must also be connected to earth.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Low volatge through normal cable 5 460 Sat Mar 15, 2008 5:30 pm
3 core cable into normal light fitting 7 860 Sat Apr 14, 2012 6:47 pm
Induction hob - Normal 13 amp plug? 33 12120 Mon Aug 15, 2011 7:54 pm
REPLACING NORMAL DOUBLE LIGHT SWITCH TO A DOUBLE DIMMER PROB 5 80 Wed Jun 22, 2011 9:27 pm
2 gang light switch w/ dimmer AND normal switch 3 260 Thu Sep 01, 2011 10:05 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
