DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Johnson and Starley Warm air heater
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  Bookmark and Share View previous topic :: View next topic
Author Message
dl
from United Kingdom
Thanked: 0 times
PostPosted: Thu Apr 05, 2007 12:40 pm    Post Subject:
Reply with quote Thanks
Hi I am after some information about replacing my warm air heating with a combination boiler. I have a top floor flat (2nd floor) and has concrete floors I have had a plumber out who says that he has to chase the floor then run the pipes in conduit so the concrete don't eat away at the copper pipes. My main concern is that the boiler would have to go in the same place as the warm air heater so would it be ok to use the same place were the original flue went, this goes straight up out the roof.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Gasguru
from United Kingdom
Thanked: 93 times
PostPosted: Thu Apr 05, 2007 2:20 pm    Post Subject:
The warm air unit is probably flued to a ridge tile vent. There are some boilers that can utilise a similar arangement; however it is normal to use a purpose designed vertical flue kit. Ideally the heating pipework should be laid in covered ducts within the floor screed to allow future maintenance/inspection.
You may require permission from the freeholder when installing the new flue terminal or pipework through the walls/roof (as you don't own them).
Also check under your lease you are permitted to install a wet central heating system.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 665 times
PostPosted: Thu Apr 05, 2007 4:17 pm    Post Subject:
I would be more worried about damaging the floors. I would not like to hear that your floor has collapsed!
Sometimes there is a weak mix topping which can be used to contain pipes and cables but in most cases the floor should not be disturbed for structural reasons.
Be aware you will need a condensate drain connection for the new boiler.
Tony
Back to top
 Alert Moderators
cozzmic
from United Kingdom
Thanked: 9 times
PostPosted: Thu Apr 05, 2007 5:09 pm    Post Subject:
Any reason not to fit a Part L compliant WAU. Look up the J&S web site and the Economaire units. It would be a simple change and may not have to renew all the flue and not cut the floor. If not do you have access to a roof space above your property to drop feed to rads from a combi boiler.
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 25 times
PostPosted: Thu Apr 05, 2007 6:20 pm    Post Subject:
Out of interest as a Warm Air unit is NOT a boiler when did they come under the Part L reg?
__________________
If at first you don't succeed, remove all evidence you ever tried.
Back to top
 Alert Moderators
cozzmic
from United Kingdom
Thanked: 9 times
PostPosted: Thu Apr 05, 2007 7:37 pm    Post Subject:
Couldn't tell you but J&S are promoting it so must be true me thinks.
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 25 times
PostPosted: Thu Apr 05, 2007 7:59 pm    Post Subject:
nope
a warm air unit does not come under part l
maybe the water heater
__________________
Back to top
 Alert Moderators
cozzmic
from United Kingdom
Thanked: 9 times
PostPosted: Thu Apr 05, 2007 8:32 pm    Post Subject:
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 25 times
PostPosted: Thu Apr 05, 2007 8:36 pm    Post Subject:
cozzmic wrote:
Check the link.
http://www.johnsonandstarleyltd.co.uk/ammend/prod_warm.asp?p=econom
cheers mate
I will call them monday and ask em about it
as WAU are not boilers
__________________
Back to top
 Alert Moderators
cozzmic
from United Kingdom
Thanked: 9 times
PostPosted: Thu Apr 05, 2007 8:47 pm    Post Subject:
No probs corgiman but I know some of us have to work on Monday but I think J&S will be on there hols. icon_lol.gif
Back to top
 Alert Moderators
Paul Barker
from United Kingdom
Thanked: 100 times
PostPosted: Thu Apr 05, 2007 9:13 pm    Post Subject:
Water heaters aren't required to be steamers.
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 25 times
PostPosted: Thu Apr 05, 2007 10:01 pm    Post Subject:
DOH
alright for some
I am having to work the entire weekend
AGAIN
__________________
Back to top
 Alert Moderators
Paul Barker
from United Kingdom
Thanked: 100 times
PostPosted: Fri Apr 06, 2007 7:26 am    Post Subject:
Still mildly on topic, after quite a few old people living in certain housing round here that is Johnton and Starky heated I decided to take myself off the Hull (the UK capital of warm air heating) for the training and qualification.
Of course I haven't had a bloomin call about it ever since, but I suppose I have 5 years to claw back the £320 (well £770 if you add in opportunity cost)
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 25 times
PostPosted: Fri Apr 06, 2007 12:22 pm    Post Subject:
LMAO
My guv made me do the same paul
so far I have serviced TWO
lmao
brilliant
__________________
Back to top
 Alert Moderators
nickso
from United Kingdom
Thanked: 91 times
PostPosted: Fri Apr 06, 2007 1:08 pm    Post Subject:
corgiman wrote:
LMAO
lmao
brilliant
you lucky b*****d....i must have done hundreds of them
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
cost of johnson Starley J32 Hispec warm air heater 2 5680 Wed Aug 24, 2005 1:58 pm
Johnson & Starley Warm Air Boiler. Series 2 17 600 Mon Jun 28, 2010 12:06 pm
Johnson & Starley or Radiators? Opinion & Prices? 21 2000 Sat Jul 18, 2009 6:44 pm
Johnson & Starley Hi-Spec M31 Pilot Light 3 200 Sat Jan 02, 2010 11:57 am
Johnson and Starley Modair JT1925 problem 3 400 Sat Jan 03, 2009 11:52 am
Varme Carbon Heating Film 15.0sqm & 20sqm Depron Varme Carbon Heating Film 15.0sqm & 20sqm Depron£530.04Varme Carbon Heating Film 7.0sqm & 10sqm Depron
Varme Carbon Heating Film 7.0sqm & 10sqm Depron£284.74
Varme Carbon Heating Film 18.0sqm & 20sqm Depron Varme Carbon Heating Film 18.0sqm & 20sqm Depron£607.66Varme Carbon Heating Film 9.0sqm & 10sqm Depron
Varme Carbon Heating Film 9.0sqm & 10sqm Depron£336.49
Varme Carbon Heating Film 2.0sqm & 10sqm Depron Varme Carbon Heating Film 2.0sqm & 10sqm Depron£155.37Varme Carbon Heating Film 22.0sqm & 30sqm Depron
Varme Carbon Heating Film 22.0sqm & 30sqm Depron£749.46
DIYnot
