DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Hanging Ledge & Brace Doors + Hinge Fronts
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
LRich
from United Kingdom
PostPosted: Fri Apr 06, 2007 12:15 am Reply with quote
Hi all,
As topic suggests, I have ledge and brace doors to hang...
Looking at the planked face of the door, some of them open towards you, and some away. For the sake of them all looking the same, I want to put the matching dummy 'hinge fronts' on the face of the doors which open 'away' (and vice versa).
But I'm having hell of a time finding working hinges with matching dummy hinge fronts. (At a good price of course)
Anyone got any leads?
I need 400mm/18" ish and 300mm/12" ish.
I'm starting to wonder if I'm missing a trick in hanging these with tee hinges, otherwise I'd be finding what I'm after surely??
How do you normally tackle this problem?
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 935 times
PostPosted: Fri Apr 06, 2007 8:44 am Reply with quote
you just grind [file or cut] the pin out enlargen the gap between the fingers slightly for clearence shut the door and fit the hinges
and of course i am assuming the doors are inward opening for security!!!!
Back to top
 Alert Moderators
LRich
from United Kingdom
PostPosted: Fri Apr 06, 2007 10:45 am Reply with quote
Thanks for the reply. (Sorry I don't know what you mean by 'fingers')
They are internal doors, so security isn't an issue.
As I said in my post, some open inwards, some open outwards, hence I'm having this problem.
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 935 times
PostPosted: Fri Apr 06, 2007 2:45 pm Reply with quote
where the two halves of the hinge touch you need to slightly open the gap otherwise as the door moves with contraction and expansion the two halves won't line up
forgot to mention if the side of the door your fitting your dummy hinges to is onto a door stop just cut the hinge short of the knucle [bendy bit]and recess the end of the cut hinge 5mm into the door stop to stop a gap showing icon_wink.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Shutters for kitchen unit fronts? 2 580 Tue Jul 03, 2007 2:32 pm
Ledge & Brace Doors + Tee Hinges ; Choosing Hinge Size 3 1540 Thu Apr 05, 2007 10:56 pm
Ledge and Brace Doors 2 120 Thu Mar 22, 2012 8:24 am
Internal window ledge replacement? 5 720 Wed Feb 22, 2012 11:36 am
Door hanging off hinge 2 40 Sun Jun 30, 2013 1:51 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
