DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Replacing my flat roof
This topic originated from the How to page called Flat Roof
Click here to return to the page called Flat Roof.
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
  View previous topic :: View next topic
Author Message
Hoonster
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 07, 2007 1:41 pm    Post Subject:
Reply with quote Thanks
Help!!! Ive just been quoted for £800 to replace a 10ft by 8ft flat roof. This seems a bit steep...or am I livin in la la land? Is that about right?
The price is inclusive of replacing the boards underneath, the facias etc.
_____________________________
lynda, moderator
please note forum rule 9 (get more quotes)
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
nstreet
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 07, 2007 2:17 pm    Post Subject:
I replaced a flat roof of approx the same size last year using cold lay. I also replaced the boards. Materials were around £300 and it took 3-4 days, so i woul say it sounds about right, especially if you are in the London area.
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 71 times
PostPosted: Sat Apr 07, 2007 2:52 pm    Post Subject:
Re: Replacing my flat roof
seriously, this is about right for the work involved. anything under a £1000 would be acceptable.
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Thu Apr 12, 2007 7:26 pm    Post Subject:
Back to top
 Alert Moderators
sandwell
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 15, 2007 8:12 pm    Post Subject:
Sounds very reasonable price to me.
Back to top
 Alert Moderators
In Your Face
from United Kingdom
Thanked: 0 times
PostPosted: Fri Apr 20, 2007 10:01 am    Post Subject:
This is a good price as long as the materials & workmanship is quality. Hot bitumen, High performance felt & lead flashing should be used and keep away from the torch on unless its a new build with no hidden cavities under your roofing deck.
Back to top
 Alert Moderators
adybuttress
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 22, 2007 6:55 pm    Post Subject:
flat roof costs
I had a reasonable quote from permaroof.co.uk they use a rubber membrane made by Firestone that has a 20 year warranty which appealed to me. Obviously i took them up and they did an excellent job.
I know its a bit of a lump of money to find when a flat roof goes, but at least with this system ive gone with, its now sorted for good.
hope this helps
Back to top
 Alert Moderators
owsian
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 29, 2007 4:58 pm    Post Subject:
permaroof
if i may ask.....how much was your roof as i am thinking of having exactly the same thing done.
ian
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
Flat roof needs replacing,Which is best Asphalt or rubber 2 1400 Fri Oct 13, 2006 1:10 pm
replacing joists in flat garage roof 13 380 Sat Jan 10, 2009 10:05 am
replacing fascia boards on a flat felt roof 3 920 Wed Apr 23, 2008 8:09 pm
replacing part of a flat roof wth polycarbonate sheets 2 760 Sat Aug 12, 2006 3:01 pm
Replacing Dormer Flat Roof 3 820 Sun Oct 05, 2008 8:05 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
