DIYnot
Local | Network
   DIYnot > Forums
Local | Network
plaster cornice and polyurethane panelling: preparation?
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Author Message
sunama
from United Kingdom
Thanked: 1 time
PostPosted: Sun Apr 08, 2007 2:11 am Reply with quote
I have installed onto newly plastered walls/ceiling:
1. plaster cornice
2. polyurethane (plastic-type) panelling on the ceiling.
I have almost finished putting them both up and filling on the gaps.
I am now about to start painting the ceiling/walls.
My question
I shall be using Dulux Trade Supermatt (diluted 30%) to first prime the walls and ceiling. However, should I use the same paint to prime the cornice and panelling or do I have to use PVA solution or similar, first?
The panelling on the ceiling has its mitres filled in with coving adhesive/filler and the corners feel a little fragile, ie. if i take a screwdriver I can easily start scraping away and damaging the corners that were finished with the filler. Surely I cannot paint the panelling while it is in this condition? It needs to be stronger, this is why I was thinking about using a coat of PVA solution, first.
Thanks.
Back to top
 Alert Moderators
Third_Eye
from United Kingdom
Thanked: 4 times
PostPosted: Sun Apr 08, 2007 1:45 pm Reply with quote
Any chance of a few pics ?
Back to top
 Alert Moderators
sunama
from United Kingdom
Thanked: 1 time
PostPosted: Sun Apr 08, 2007 11:30 pm Reply with quote
A pic of the cornice that is installed.
Its quite large.
It has a 220mm projection, 150mm height.
Here is a pic of the panelling in the middle of the room, incomplete - I still need to do some work on it.
Here is the same panelling, in its earlier stages, however, the pic was taken in better lighting and with a wider pan, so you can see it better here.
If I take a scrwedriver to the corners of the panelling, it can chip and fall apart quite easily. I finished the corners using decorators caulk. Is there anyway I can strengthen it - perhaps by brushing pva solution on it? Or, do I simply treat the panelling and cornice as I would the ceiling and paint it (mist coat, then 2 coats of 90% Dulux Matt Paint)?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
Oil-based polyurethane 6 720 Tue Dec 05, 2006 9:18 am
polyurethane varnish on old softwood flooring 9 140 Thu Sep 15, 2011 1:42 pm
Removing polyurethane varnish.....HELP! 7 100 Sat May 11, 2013 1:19 pm
Painting panelling 3 1540 Wed Sep 11, 2002 8:26 pm
Painting over dark stained/varnished panelling 2 600 Wed May 26, 2010 10:20 am
DIYnot
