DIYnot
Local | Network
   DIYnot > Forums
Local | Network
how to get a shower hotter ??
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
chezzer0361
from United Kingdom
PostPosted: Sun Apr 08, 2007 7:43 pm Reply with quote
got a "shower force gravity fed shower ", to go with the comb bolier, can't remember what type T something, any way, the dial goes from 1 - 9, 9 being the hottest, but it only gets warm at 7, but it only goes up to 9.
Is there any way of slowing the cold water down so it gets hotter quicker and therefore gets hotter/ scalding all the way up to 9, if that makes sense. I have it on 9 which is nice but not hot, but as it is on 9 it will not go any warmer.
Back to top
 Alert Moderators
KillingTime
from United Kingdom
PostPosted: Sun Apr 08, 2007 8:02 pm Reply with quote
All electric showers I've been in get scanding hot when turned to max, but I have no experience with your model.
1. Check the cable to the shower is the right diameter (10mm2 I think - check this). If your cable is not thick enough, the heater element will not be able to draw the current it needs to heat the water.
2) If this is an old shower unit (bought second hand?) then the element may be firred up with deposits. Ie inefficient. -> replace.
3) If all else fails, you could fit a pressure reducer (avail from screwfix) or if your on a budget, just fit an isolation valve in line with the shower unit and partially close it to reduce the flow.
Back to top
 Alert Moderators
chezzer0361
from United Kingdom
PostPosted: Sun Apr 08, 2007 8:39 pm Reply with quote
thanks, but it is not a electric shower does the same apply ????????
Back to top
 Alert Moderators
KillingTime
from United Kingdom
PostPosted: Sun Apr 08, 2007 8:47 pm Reply with quote
sorry, thought you had an electric shower.
Increasing the temp of the water coming out of the boiler will solve the problem. I' don't know much about combi boilers. Try your manual for the boiler first to increase the hot water temp. This will save you having to fit the valve on the shower.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sun Apr 08, 2007 8:56 pm Reply with quote
Let me get this straight - you've bought a shower for use with a gravity feed, and connected it to a combi boiler?
Go and write out 100 times: I must read the Manufacturer's Instructions.
What?!
What?!
Quote:
...or if your on a budget, just fit an isolation valve in line with the shower unit and partially close it to reduce the flow.
Oh. My. God.
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 380 times
PostPosted: Sun Apr 08, 2007 9:25 pm Reply with quote
Back to top
 Alert Moderators
KillingTime
from United Kingdom
PostPosted: Sun Apr 08, 2007 10:28 pm Reply with quote
chezzer0361, what Softus means is that you're meant to fit a gravity shower mixer to the hot water cylinder and cold water tank.
Just increase the hot water temp from your bioler. Other than that, you'll have to replace the mixer.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sun Apr 08, 2007 10:35 pm Reply with quote
Er, I'm more than capable of writing what I mean, and I wrote what I meant, which isn't what you wrote.
Below is an example of me expressing what's on my mind....
What the f*** are you talking about? Have you checked whether or not this shower contains a pump? Have you checked whether or not it can cope with unbalanced supplies? Have you checked anything? Do you have the slightest clue what you're talking about?
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 787 times
PostPosted: Mon Apr 09, 2007 12:35 pm Reply with quote
With Softus on this one, MI's should state that it is suitable for combi installation and/or mains pressure use. Some 'universal' showers need to have a flow restrictor fitted in the cold supply side of valve connection. Again CHECK M I's icon_rolleyes.gif
Back to top
 Alert Moderators
chezzer0361
from United Kingdom
PostPosted: Tue Apr 10, 2007 10:47 am Reply with quote
thanks I will see if I can find the book....................... icon_rolleyes.gif
Back to top
 Alert Moderators
chezzer0361
from United Kingdom
PostPosted: Wed Apr 11, 2007 11:43 am Reply with quote
just been on and you can use this shoer with a combi-boiler, tried turing up the water temp on boiler but didnt make any difference, just made the radiators bang, but thats another story, so I guess its just put up with it, they say you can fix a pump to make the water more powerfull, but dont think this will help.
Back to top
 Alert Moderators
NickStone
from United Kingdom
PostPosted: Wed Apr 11, 2007 12:10 pm Reply with quote
Chezzer, I don't know much, but this much I do know. You cannot fit a pump if you have a combi boiler.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 787 times
PostPosted: Wed Apr 11, 2007 6:06 pm Reply with quote
It hasn't got one of those temperature limiting tags fitted on the mixer that can be removed thus letting you turn it more to make shower hotter has it?
A lot these days have these fitted by manufacturers. Again check M i's to find out!
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 80 times
PostPosted: Wed Apr 11, 2007 6:26 pm Reply with quote
Sorry but can't resist this one
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Shower dripping & NOW RUNNING HOTTER? 4 260 Tue Jun 30, 2009 7:07 am
how to make my shower hotter? 9 680 Mon Oct 15, 2012 2:33 pm
Is it possible to make my shower hotter?? 19 400 Mon Feb 25, 2013 3:23 pm
Thermostatic shower - need to turn it hotter & hotter 6 100 Sat Mar 08, 2014 7:48 pm
How do I get my water hotter in a Baxi Bahama 100 3 480 Thu Feb 02, 2006 2:59 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
