DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Expantion Cistern overflows
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
ironfist4628
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 10, 2007 1:03 pm    Post Subject:
Reply with quote Thanks
My expantion cistern in the loft keeps overflowning. I've replaced the ball valve and it shuts off ok but it still overflows. Is there another explanation to this problem? Any advice would be appreciated thanks.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Lagerkhan
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 10, 2007 1:21 pm    Post Subject:
Re: Expantion Cistern overflows
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 59 times
PostPosted: Tue Apr 10, 2007 1:25 pm    Post Subject:
What he means is if coil in cylinder is holed or split it allows the water in your large tank in loft and the small tank to mix and find it`s own level which is usually above the level of the overflow thus it drips
Back to top
 Alert Moderators
Lagerkhan
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 10, 2007 1:29 pm    Post Subject:
Back to top
 Alert Moderators
ironfist4628
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 10, 2007 2:36 pm    Post Subject:
Thanks for your quick replies. I'll look into that later and let you know how I get on. Thanks again
Back to top
 Alert Moderators
Bamber gaspipe
from United States of America
Thanked: 0 times
PostPosted: Tue Apr 10, 2007 2:48 pm    Post Subject:
Or quickly open your Hot taps & check colour. If your coil is split your Hot water is normally a murky brown colour & may smell especially if inhibitor has been added.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Tue Apr 10, 2007 10:16 pm    Post Subject:
Nonsense.
Back to top
 Alert Moderators
bab
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 10, 2007 10:35 pm    Post Subject:
if its the heating f/e thats over flowing then its clean water entering the heating not causeing smell or contamination. if the heating tanks the higher of the tanks & its the domestic hot water cold tank over flowing the hot water could be contaminated but a drip drip drip ould probably go undetected in a large volume of water.
__________________
You can run but you cant hide.
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 59 times
PostPosted: Wed Apr 11, 2007 6:59 am    Post Subject:
Although it doesn`t happen everytime a split coil will give dirty water out of hot taps because your getting all the crap pumped out of heating circuit into the cylinder
Back to top
 Alert Moderators
ironfist4628
from United Kingdom
Thanked: 0 times
PostPosted: Wed Apr 11, 2007 10:19 am    Post Subject:
Hot water is coming out clean at the moment. I'll drain the cylinder later and see if the level drops in the heating cistern. I think that's the only way I'll know for sure.
Back to top
 Alert Moderators
defonarival
from United Kingdom
Thanked: 0 times
PostPosted: Wed Apr 11, 2007 7:19 pm    Post Subject:
you can tell if the coil is faulty in the cylinder as the Feed and expansion tank would be constantly topping up, I would be more inclined to investigate any monobloc/mixer taps that you have as its more likely to be one of these at fault.
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 59 times
PostPosted: Wed Apr 11, 2007 7:28 pm    Post Subject:
Its his heating expansion tank over flowing so why would it be a mixer tap
Back to top
 Alert Moderators
Lagerkhan
from United Kingdom
Thanked: 0 times
PostPosted: Wed Apr 11, 2007 7:33 pm    Post Subject:
icon_rolleyes.gif icon_rolleyes.gif icon_rolleyes.gif icon_rolleyes.gif icon_rolleyes.gif
Back to top
 Alert Moderators
ironfist4628
from United Kingdom
Thanked: 0 times
PostPosted: Wed Apr 11, 2007 7:42 pm    Post Subject:
I drained the cylinder today by opening all of the hot water taps and shutting of the ball valves in both tanks in loft. If I'm right, this would normally empty just the big expantion tank, but it also emptied the small expantion tank. This must prove what Largerkhan and namsag said about a hole or split in the coil.
Back to top
 Alert Moderators
Lagerkhan
from United Kingdom
Thanked: 0 times
PostPosted: Wed Apr 11, 2007 7:47 pm    Post Subject:
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Heating expantion tank slowly backfilling 2 400 Sun Sep 30, 2007 5:15 pm
combi with header expantion tank 3 340 Sun Oct 09, 2005 2:50 pm
Expantion Tank 3 400 Tue Jan 31, 2006 9:30 am
Assembling wastes and overflows 2 500 Sat Aug 26, 2006 6:21 pm
ideal boiler C24 water overflows from external pipe 3 500 Wed Jan 17, 2007 2:37 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
