Hi. I have an AWM 8163, and it's coming up with the "PF" code. I know how to drain the machine manually and remove items from the pump.
It has always worked in the past, but not this time. I removed a 5p piece, but it still failed. I opened it up again, and there was some foil and card from a cat food packet in there, which I removed. Still no joy.
It drains most of the water each time, but leaves about 2 or 3 litres behind. The impeller is turning OK.
There doesn't appear to be anything in the pump impeller or cavity, and the hole on the left (I assume to the drain) is clear.
Any other ideas, or is it service engineer time?
