Bunge
Joined: 11 Apr 2007 Posts: 2 Location: London, United Kingdom Thanked: 0 times
Posted: Wed Apr 11, 2007 3:09 pm Post Subject: Replacing a double light switch |
I wish to replace an existing \\\'double\\\' lightswitch in the lounge with a new one, but the terminals in the new switch are different from the old and I am unsure how to proceed. The two switches control two sets of lights (wall and ceiling) in the same room. They can both be on at the same time.
The existing double switch has the following terminals in one block:
top: Com/L1/L2
bottom: L1/L2/Com
The existing wiring is:
Cable 1:
Red to bottom Com with a loop wire to bottom L1
Black to top L1
Cable 2:
Red not connected to anything - hanging loose in wall box
Black connected to top Com
The replacement switch has the following terminals in two blocks:
Top: L / L
Bottom: L1/L2 then L1/L2
Can you help me connect the replacement switch , please. |
davy_owen_88
Joined: 17 Nov 2006 Posts: 1680 Location: West Glamorgan, United Kingdom Thanked: 0 times
Posted: Wed Apr 11, 2007 3:14 pm Post Subject: |
Cable 1:
Red to L with a loop wire to the other L
Black to L1
Cable 2:
Black connected to other L1 |
Bunge
Posted: Fri Apr 13, 2007 12:10 pm Post Subject: Replacing a double light switch |
Many thanks for your help - I'll try it over the weekend |
