| Author |
Message |
mark.carline
Joined: 01 Apr 2006 Posts: 209 Location: Cheshire, United Kingdom
Posted: Thu Apr 12, 2007 2:25 pm |
I guess its related to plumbing and central heating  but does anyone here know more about the following:
http://www.ciob.org.uk/news/view/1359
quote:
| Quote: | | To play our part, I am offering grants of £300 to £4,000 for pensioners installing insulation and central heating in their homes |
Both our parents have standard types of boilers (one has a combi and the other a standard boiler with storage tank) and I wondered how these grants could be used to get these replated with new condensing high efficiency ones ? |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
cozzmic
Joined: 20 Jan 2005 Posts: 686 Location: Nairnshire, United Kingdom Thanked: 46 times
Posted: Thu Apr 12, 2007 4:01 pm |
Don't count on anything, my mums boiler was worn out 15+ year old combi, parts prohibitivly expensive so condemed it. Tried to get a free boiler which she is entitled too but was knocked back as it as still working at a reduced capacity. Then it burst after she had bought a replacement herself so asked if we could get a monetary sum for a replacement boiler but again knocked back.
I know of other people who have got these free systems as they are pensioners but they are absolutly minted but its not means tested. If they haven't got central heating they are entitled to get 5 or 6 rads and a boiler thrown in (sorry installed). |
| Back to top |
gas4you
Joined: 23 Feb 2007 Posts: 16902 Location: Norfolk, United Kingdom Thanked: 491 times
Posted: Thu Apr 12, 2007 4:05 pm |
Warm front grant of £300 has been extended. This is available to anyone who is not on any form of benefit. Must either have a non-functional heating system of only a single point of heat eg coal fire to qualify.
Local councils may be able to help but this is usually a 'loan' that has to be repaid in part if you move within 10 years or so. |
| Back to top |
sambotc
Joined: 10 Apr 2007 Posts: 579 Location: United Kingdom Thanked: 14 times
Posted: Thu Apr 12, 2007 7:02 pm |
I am an installer for a warm front registered company. I fit these systems day in and day out. Here's some info:
If you need help paying for heating and insulation improvements in your privately owned or rented home, you, your partner or civil partner may be able to get money from the government's Warm Front grants scheme if, for example, you're receiving income or disability-related benefits.
Who is eligible?
You may get a Warm Front grant if any of the following apply to you:
1. You get one or more of the following benefits:
Working Tax Credit (with an income of less than £15,050 and which must include a disability element)
Child Tax Credit (with an income of less than £15,050)
Attendance Allowance
Disability Living Allowance
Income Support (that must include a disability premium)
Housing Benefit (that must include a disability premium)
Council Tax Benefit (that must include a disability premium)
War Disablement Pension (that must include a mobility supplement or a Constant Attendance Allowance)
Industrial Injuries Disablement Benefit (that must include Constant Attendance Allowance)
2. You have a child under 16 or are pregnant and have a maternity certificate MAT B1 and get any of the following:
Income Support
Council Tax benefit
Housing Benefit
income-based Jobseeker's Allowance
Pension Credit
3. You're aged 60 or over and get any of the following:
Pension Credit
Council Tax Benefit
Housing Benefit
4. You're not getting any benefits
You may be entitled to a Warm Front grant even if you're not yet getting any qualifying benefits. A check will be done to see if you're eligible for benefits and so a Warm Front grant.
Income Support factsheet
Council Tax Benefit factsheet
Pension Credit factsheet
How much do you get?
£2,700 or up to £4,000 if your home needs oil central heating.
How it works
A Warm Front appointed engineer will complete a technical survey of the work needed for the existing heating system in your property.
If for example your property needs a replacement boiler, work will be carried out within six to eight months of the technical survey.
You won't have to pay anything so long as the work doesn't cost more than the grant.
In some cases you might have to pay towards the work but wherever possible, the scheme will try to cover these costs.
What you can use it for
The Warm Front grant provides insulation and heating improvements depending on your needs and the property you live in. The package includes:
Insulation
loft insulation
draught proofing
cavity wall insulation
hot water tank insulation
Heating systems
gas room heaters with thermostat controls
gas, electric or oil central heating
converting a solid fuel open fire to a modern glass fronted fire
timer controls for electric space and water heaters
Other measures
energy advice
two low energy light bulbs
HTH Sam |
| Back to top |
gas4you
Posted: Thu Apr 12, 2007 7:09 pm |
The warm front grant I mentioned is different from what Sam is refering to. His indeed is a scheme to get a complete boiler change or heating system fitted if you are on some sort of benefit, my literature states up to £2700.
The one I refer to is called the Warm Front heating rebate scheme and is for only £300.
You must
1 own your own home or rent privately
2 without a heating system or yours has broken down
3 be 60 or over
4 not be in receipt of any benefits |
| Back to top |
sambotc
Posted: Thu Apr 12, 2007 8:20 pm |
Not aware of the scheme you mentioned above. What does the £300 pay for, repairs?
I know most of the 'repairs' we go to normally end up being 'replacement boilers' for obvious reasons.
Cheers, Sam |
| Back to top |
gas4you
Posted: Thu Apr 12, 2007 9:02 pm |
This scheme is just for people who are not receiving any benefits and over 60. It is limited to £300 and this is issued as a voucher to the householder, who then gives this to the registered installer who then sends this in to warm front and gets £250 for it! £50 admin charge!
It is towards a new boiler. |
| Back to top |
mark.carline
Posted: Fri Apr 13, 2007 12:38 pm |
thanks guys
I thought my hopes where going to be dashed as I had hoped that this scheme would incourage people to have standard boilers to get them replaced with high energy efficient ones. I think the maths currently show that the savings in fuel bills after getting a condensing boiler replaced are not really gained back compared with the installation costs (or not in the short term anyway). |
| Back to top |
Natlancsz
Joined: 20 Mar 2011 Posts: 1 Location: Blackpool, United Kingdom
| Back to top |
simond
Joined: 26 Oct 2004 Posts: 3980 Location: Surrey, United Kingdom Thanked: 257 times
Posted: Sun Mar 20, 2011 11:47 pm |
There's nothing like timely, educated, useful advice.
And this is nothing like it. |
| Back to top |
DP
Joined: 10 Dec 2003 Posts: 5523 Location: Glasgow, United Kingdom Thanked: 406 times
Posted: Mon Mar 21, 2011 9:47 am |
Better late than never!! |
| Back to top |
