kevinspark
Joined: 14 Apr 2007 Posts: 32 Location: United Kingdom Thanked: 0 times
Posted: Sat Apr 14, 2007 7:55 pm Post Subject: New Ceramic Hobs? |
Hi Guys,
I installed a new ceramic hob today, unfortunately the homeowner had bought it on the cheap with no instructions etc. After wiring it in, I turned it on and found that after turning on all the rings, the rings went off after about 5 seconds or so, the people havent moved in yet, so no pans to try it on. Although theres still power going to it (the led stays on).
With the ones Ive previously installed theyve had sensors to detect for pans and if no pans its turned off the rings.
Just wondering if this was the norm for the ceramic hobs now or what. |
Steve
Joined: 15 Apr 2005 Posts: 12857 Location: Yorkshire, United Kingdom Thanked: 22 times
Posted: Sat Apr 14, 2007 8:06 pm Post Subject: |
The rings run on thermostats. I doubt after 5 seconds they would be at temperature. Did you leave them on and watch them cycle? Did the "heat" lights come on?
I've never seen a hob with sensors for pans. But i dont install them or anything. Did you sling a pan of water on there to check if this was the case? |
kevinspark
Posted: Sat Apr 14, 2007 8:08 pm Post Subject: |
they got pretty hot, way too hot to tough anyway. they were glowing red fine, then after turning them off and right back on again they stayed on less time which had me thinking there were too hot without a pan on.
no didnt put any water on it or anything, when the led stayed on through it all, and putting my clamp meter on it and seeing it still pulling current, I got told to move to the next call. |
JonB
Joined: 09 Apr 2005 Posts: 452 Location: Cleveland, United Kingdom Thanked: 6 times
Posted: Sun Apr 15, 2007 3:54 am Post Subject: |
We have a German ceramic hob with 4 rings 1 being halagon.
It has 4 indicating lights which stay on even when the ring is turned off, to show that they are still hot. Obviuosly going off as they cool down.
Also the fan keeps running in the double oven until the doors are cool. |
kevinspark
Posted: Sun Apr 15, 2007 7:31 pm Post Subject: |
Yeah, Seems rather strange, but with the power still getting to the hob (ie, the led staying on throughout). Id say it wasnt a wiring problem and more than likely something with the hob.
Ill have to see if I can pop in tomorrow and get a brand name and look for some online documentation. |
