I'm a little bit dinosaur but not quite as extinct or fossilised as Kev
I use Hep20 quite frequently and have no problems with it, however I dont like using it on any pipework that is on show or is not likely to be boxed in.
If vermin were an existing problem then I would also rule it out.
I dont like Speedfit with the exception of their stop end fittings.
Other makes of plastic come under the category of 'crap they sell in the sheds' I only ever use said crap in an emergency.
Everyone has their own philosophies, experiences and practices and this is just mine. Hep fittings come with instructions and if you follow them and use comon sense then you should have no problems. The same could well go for other makes of pipe but I just never go there.
Hep20 came out in about 1979/80 as 'Acorn' fittings The idea was that you used just the fittings on copper pipe. The plastic pipe was not available for a while after the launch. [I still have a leaflet for them kicking about here somewhere.] This in itself made life a lot easier for me and I suggest you consider this method if you are looking for a compromise.
Around about 1991 I fitted my sisters heating system on a budget with the now re-launched and re-coloured Hep20 in microbore using second hand radiators and a ferroli boiler. The same system is still going strong today even though I was supposed to go round and change a leaking PRV over 2 years ago.
Top tips
Use the proper cutting tool for the plastic pipe.
Ditto for copper.
Dont forget the inserts. Develop a routine so you dont miss any out.
Dont expect the fittings to grip on chrome pipe.
If you have any doubts about whether the fitting is on properly TAKE IT APART TO CHECK
Check each fitting has all of its components and is correctly assembled before you use it.
Dont use pipe that has been kinked or fit it in an overstressed position or against anything where expansion and contraction can cause the pipe to rub and wear.
READ THE INSTRUCTIONS
