DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Mira Sprint Shower
This topic originated from the How to page called Installing a shower
Click here to return to the page called Installing a shower.
Goto page 1, 2, 3  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
scm8jmh
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 16, 2007 5:47 pm    Post Subject:
Mira Sprint Shower
Reply with quote Thanks
My Mira sprint shower stopped providing hot water yesterday after I put temp up really high...i think i might have tripped a heat limit on it?? Its only just over year old so i would hope not water heater. Can anyone advise what I need to test or how to be sure what wrong?
Thanks James
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
sambotc
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 16, 2007 6:04 pm    Post Subject:
Any sign of power to the unit or pull cord? If not check to see if the fuse has blown, or tripped on the consumer unit. Providing there was a decent flow of water i can't see the shower overheating under normal operating conditions i think there's a light on those for overheat isn't there? Is this on?
HTH Sam
Back to top
 Alert Moderators
scm8jmh
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 16, 2007 6:29 pm    Post Subject:
Thanks! there is power as it turns on fine...
It has constant cold water flowing now...but i needed very hot water so turned it right up...the flow did slow down.....then i turned it back to normal...
Back to top
 Alert Moderators
sambotc
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 16, 2007 6:45 pm    Post Subject:
Can you switch it off at the main and back on again? The flow would drop when turned up higher as this is how the water comes out hotter. AFAIK the element temp does not adjust in any way, just water is throttled down so it takes longer to pass through the heating element, therefore getting hotter. Correct me if i'm wrong anyone.
Do you have any way of testing if there is power to the element?
Sorry i can't be any more help, Sam
Back to top
 Alert Moderators
scm8jmh
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 16, 2007 7:05 pm    Post Subject:
Ive turned it off at main and back on....
Im not very good at these things, how i check power to element?
Back to top
 Alert Moderators
sambotc
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 16, 2007 7:37 pm    Post Subject:
Well it would mean testing for power across the terminal's of the element but with the casing off and the water running, so if you don't feel comfortable with these thing's i strongly recommend you get someone who does in to do this, as water and electric... you get my point! icon_eek.gif
Is it still under warranty with mira?
Back to top
 Alert Moderators
scm8jmh
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 16, 2007 7:39 pm    Post Subject:
Was hoping to avoid getting someone in...prob cost more tha buying a new one!! but ur right, i wudnt have a scooby what im doing!!
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Tue Apr 17, 2007 8:41 am    Post Subject:
Turning up to maximum will stress two components that might have been waiting to fail, these being the heater can and the overheat cut-out. It's also possible the flow control valve has stopped working, but I'd expect fast tepid water if that were the case.
Isolate the unit electrically, then test the resistance of the elements. I don't know what they should be, but it's not hard to work it out from the power rating. Also test the cut-out switch, which should be showing continuity.
Back to top
 Alert Moderators
scm8jmh
from United Kingdom
Thanked: 0 times
PostPosted: Thu Apr 19, 2007 6:16 pm    Post Subject:
Thanks!
How do i resistance test the elements?
Whats the cut out switch?
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Thu Apr 19, 2007 7:09 pm    Post Subject:
Do you have a multimeter of any sort?
See item 416.41 in the diagram below.
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 19 times
PostPosted: Thu Apr 19, 2007 8:20 pm    Post Subject:
7.7 ohms approx for a 7.5Kw shower down to about 5.5 ohms for a 10.5Kw (for 240V rated )icon_wink.gif
So somewhere proportionally in between if your shower falls somewhere between these two power ratings
__________________
Empty barrels make the most noise.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Thu Apr 19, 2007 8:24 pm    Post Subject:
This one, as with most electric p*ss pots, has two elements ricicle, so you need to roughly double those figures for each one. icon_wink.gif
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 19 times
PostPosted: Thu Apr 19, 2007 8:25 pm    Post Subject:
__________________
Back to top
 Alert Moderators
kevcompton
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 26, 2008 7:46 am    Post Subject:
Hi, I am having the same problems ie. no hot water, just cold. There is power going to the unit as the power indicator is glowing orange. Looking at the above posts, I have checked for resistance of the Thermal Switch (416.41) and it isn't showing any reading on my multimeter. Does this imply that this part needs changing?
Could you please tell me which part on the picture is the cut out switch?
Hope someone can help.
Thanks.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Tue Aug 26, 2008 10:50 pm    Post Subject:
Yes.
416.41.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 3
Jump to:
Plumbing in Mira Sprint Shower 23 1480 Mon Jan 03, 2005 11:17 am
Mira Sprint Shower installation - rear entry supply advice 2 640 Sun Mar 29, 2009 1:11 pm
Mira Sprint hot and cold water 9 340 Mon Jul 13, 2009 9:18 pm
MIRA SPRINT 2 240 Wed Oct 01, 2008 9:07 am
Myra sprint shower unit .....hot then freezing! 3 500 Fri Aug 10, 2007 6:51 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
