Joined: 20 Apr 2007 Posts: 3 Location: United Kingdom Thanked: 0 times
Posted: Fri Apr 20, 2007 10:58 am Post Subject:
American to English plug
I have bought a glass grinder from America, i cut the sealed American plug off and put an english one on. When i switch it on i smell burning and a bit of smoke comes out. Is this because it wont convert to an English plug? Is there anything i can do to sort the problem out?
Joined: 20 Jan 2007 Posts: 2655 Location: Warwickshire, United Kingdom Thanked: 3 times
Posted: Fri Apr 20, 2007 11:39 am Post Subject:
Re: American to English plug
You will have damaged your grinder to the point where it will not work, or fail very quickly.
Do not use it again until you have it checked out/repaired.
Buy a fire extinguisher before your next electrical adventure......
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Fri Apr 20, 2007 12:44 pm Post Subject:
shiro wrote:
...it gives 115V then 230/240V 50HZ. ..
if this is on the rating plate fixed to the appliance, there may be a way of setting the voltage. Look for something like a sliding or rotating switch. It might be fixed in place with a screw. Best of all, consult the maker's instructions.
Joined: 08 Apr 2007 Posts: 8 Location: United Kingdom Thanked: 0 times
Posted: Fri Apr 20, 2007 4:22 pm Post Subject:
Crafty wrote:
Is this a joke? Are people really this stupid?
Its not a joke, its just ignorance, some people belive they are buying new electricity, when in fact they are not, there has been no new electricity since 1937
__________________ The man who's dad invented ? .....
Joined: 14 Sep 2006 Posts: 3485 Location: Gloucestershire, United Kingdom Thanked: 19 times
Posted: Fri Apr 20, 2007 8:17 pm Post Subject:
Eh?
__________________ Empty barrels make the most noise.
Joined: 20 Apr 2007 Posts: 7 Location: United Kingdom Thanked: 0 times
Posted: Fri Apr 20, 2007 9:06 pm Post Subject:
Shiro, if you want to get a converter, Maplins have got them on offer at the moment for a fiver (suitable up to 45 watts). I got one yesterday for a radio I bought in Japan, where the voltage is also 110V. If you need something bigger have a look at this page.
http://www.maplin.co.uk/Search.aspx?criteria=voltage%20converter&source=15&SD=Y
Gambatte!
Joined: 15 Apr 2005 Posts: 12845 Location: Yorkshire, United Kingdom Thanked: 21 times
Posted: Fri Apr 20, 2007 9:08 pm Post Subject:
Posted: Sat Apr 21, 2007 12:43 pm Post Subject:
Thank you all for your help. JohnD, there is no switch on the outside, just on/off one. Rabbitsnose, thanks for that, have ordered on, so hopefully all will be ok.
Joined: 27 Jul 2006 Posts: 4932 Location: Oxfordshire, United Kingdom Thanked: 63 times
Posted: Sat Apr 21, 2007 4:12 pm Post Subject:
Shiro, that £10 converter is only good for 45 watts. If your device has a motor you'll probably need a much bigger converter....
Does the voltage plate give any other info like "10amps" or "500watts"?
AS posted above, it will probably be easier to find if there is a voltage selector switch and put it on 230v. You could then plug into the UK supply - at your own risk, of course!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
