DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
outdoor switch
This topic originated from the How to page called Replacing a one way light switch with a two way light switch
Click here to return to the page called Replacing a one way light switch with a two way light switch.
  View previous topic :: View next topic
Author Message
dunkiemanuk
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 21, 2007 5:28 pm    Post Subject:
outdoor switch
Reply with quote Thanks
please help me. I have a double outdoor switch that i want to use to switch on/off a pond pump and a pond filter. I have a com, l1 and l2 on both switches. I will have a live, neutral and earth from each unit, and obviously the mains coming in to feed it. What goes where?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ELZ4742
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 21, 2007 6:33 pm    Post Subject:
feed in com, load in l1
__________________
cmon, give us a clue, i aint got a crystal ball you know....
Back to top
 Alert Moderators
dunkiemanuk
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 21, 2007 7:19 pm    Post Subject:
lol. the feed will be live, neutral and earth. I do have an earth point in the switch so that is easy, but how should the rest go? Am i being dumb here?
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Sat Apr 21, 2007 7:25 pm    Post Subject:
yes.
Tip - you dont switch the neutral with a two way switch (which you have).
Where is your feed coming from? Describe things a little better.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
i am sure this has been done before, hang on, i am going to look
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
dunkiemanuk
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 21, 2007 7:30 pm    Post Subject:
Sorry, the feed will be coming from a power socket in the shed.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Apr 21, 2007 7:40 pm    Post Subject:
i knew it had been asked before, i just found
The brown wires at the top are to your lights and pump repectivly
the brown wire at the bottom is the supply
(the orange wires are an alternative position)
all neutrals should be connected together in a choc bloc (each has its own)
all earths should be connected together in a choc bloc (each has its own)
Please tell me the supply is rcd protected and fed via an fcu with 3 or 5 A fuse
__________________
Forum = Opinions
Back to top
 Alert Moderators
dunkiemanuk
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 21, 2007 7:52 pm    Post Subject:
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Outdoor pir wont switch off 2 160 Sat Apr 25, 2009 10:35 am
Outdoor Lighting - Separate Ring / Trip switch? 5 460 Thu Apr 05, 2007 10:40 pm
outdoor lighting on normal switch if on own mcb? + 3 420 Mon Feb 12, 2007 6:14 pm
2 gang one way outdoor light switch 7 2920 Sat Apr 03, 2004 1:11 pm
Outdoor Switch Wiring 9 1540 Thu Aug 19, 2004 4:26 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
