Single Pipe Systems TRV????
12 Feb 2007
Essex
Morning All,
Another puzzling Monday after a fabulous weekend of lazing in the sun, only touble being the sun has fried my brain and I'm stumped with a current job.
I am to be carrying out a boiler swap for a customer, and want to fit TRV's to his existing radiators.
Only problem is, the current rads, only have one valve, which has two 8mm pipes going into it.
This is a vey old setup and I would prefer to rip it all out and start again. MY customers budget does not allow this, so I need to find a suitable TRV...
Searcing manufacturers web sites has so far not turned up anything useful, so my question to all you helpful people is does anyone know of such a valve and who makes it??
Answers on a postcard please, and thanks in advance :LOL: :LOL: :LOL:
How can it be a single pipe system with twin entry 8mm valves :?:
I should give up now :rolleyes:
There is one larger feed pipe, which has (I assume) two smaller 8mm pipes going to a single point on the radiator. This is I assume is to allow a flow and return somehow. I haven't worked on these kind of systems before, and although I have vague memories from my learning days, my memory isn't what it used to be unfortunately
It is a two pipe system, i.e. flow and return.
The only way to use a TRV is to reconnect the rad at opposite ends using 15 mm tube and reduce to 8 mm.
I dont think there are any TRVs made for 8 or 10 mm but I could be wrong but regardless it would be cheaper to use 15 mm parts.
Still quite a lot of work although doing it would bring the system towards replacing with proper sized pipework in the future.
Tony
I think many trvs are quite happy to accept an 8mm adaptor.
You can still get twin entry valves with TRV's, cant remeber where from mind.
Most TRVs are compatable with 8/10mm and come with internal reducers if you order the right one.
