DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Tightening sink waste
This topic originated from the How to page called Installing a bathroom sink
Click here to return to the page called Installing a bathroom sink.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
mayhewa
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 23, 2007 6:24 pm    Post Subject:
Reply with quote Thanks
Does anyone know of a tool that exists to tighten a sink waste. I need to be able to slot the tool into the pre drilled holes within the chrome sink drain that attaches to the sink icon_question.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
petetheleak
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 23, 2007 6:36 pm    Post Subject:
Try a screwdriver in each hole and use a chisel or something across the two whilst i presume you want to tighten up the backnut underneath . Hope this works dont know off a tool on the market though.
Back to top
 Alert Moderators
TicklyT
from United Kingdom
Thanked: 20 times
PostPosted: Tue Apr 24, 2007 10:25 am    Post Subject:
A pair of long nose pliers, one jaw in each hole? (a cheap pair from one of the pound shops because it certainly doesn't do much for the joint. If they are really cheap and nasty, you can file the corners off the jaws so they don't mark the chrome)
A 12" chunk of 4X2 timber with a couple of long No. 16 screws wound into it, then cut the heads off the screws so they fit in the holes?
A couple of holes in a bit of flat iron bar with 6 or 8 mm bolts projecting through them?
__________________
If it isn't broken, keep fixing it until it is
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Tightening olive on washing machine check valve 8 320 Sun Jul 27, 2008 7:08 am
Tightening loose taps. 2 980 Wed Sep 24, 2008 8:50 pm
"ping" sound when tightening compression joint 4 760 Sat Aug 21, 2004 10:08 am
tightening gland nut mains 3 280 Sat Apr 26, 2008 10:28 am
Tightening Drayton 8/10mm TRV - Strange Olives? 2 160 Thu Sep 24, 2009 11:03 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
