DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Fitting Energy Saving Downlights
This topic originated from the How to page called Types of lighting
Click here to return to the page called Types of lighting.
  View previous topic :: View next topic
Author Message
nickdem
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 23, 2007 9:02 pm    Post Subject:
Reply with quote Thanks
Hi, Can I have some advise on conecting 3 energy saving downlights to an existing 5 amp fused circuit and adding a separate one way switch to control them. Can I spur off the existing 5 amp circuit using a junction box? Where do I go then... Straight to the first of the three lights or the switch then daisy chain the lights?
If I do come off the existing 5 amp twin and earth what do I do with the earth wire, as the new downlights are double insulated.... Does this mean I can come off with just the live and the neutral 1mm wire?...... Please Help!!! icon_confused.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Mon Apr 23, 2007 9:39 pm    Post Subject:
earth wires should never be missed out.. even if the fitting is double insulated.. most pendants are..
it is there in the off chance that you change the fitting at a later date to a metal one, or in this case to a 240V downlighter, whereupon you should earth the fitting..
also it is needed so that there is an earth at the switch..
in your case i would tap off a live feed on the existing circuit and run it to the switch..
they use either a double pole switch or a single and link the neutrals in the back of it in terminal block..
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Energy Saving Downlights 9 560 Fri May 16, 2008 1:59 pm
which downlights - energy saving or low voltage? 8 640 Tue Jan 20, 2009 3:37 pm
GU10 Energy Saving Bulbs - Does this type work? 10 460 Sat Feb 28, 2009 12:02 am
Energy saving bulbs 5 440 Fri Jan 18, 2008 8:14 pm
Energy Saving Light Bulbs - Which type? 4 580 Tue Apr 08, 2008 12:51 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
