Joined: 23 Apr 2007 Posts: 5 Location: United Kingdom Thanked: 0 times
Posted: Mon Apr 23, 2007 10:33 pm Post Subject:
ARGOS kitchen Mixer Tap
I recently purchased from ARGOS Oslo Kitchen mixer mono tap supplied with copper tails .
When i tried to fit the copper tail end to the 15mm Compression elbow- the compression elbow do not hold onto the the tail end of the copper pipe - the 15 mm Compression elbow slips from the copper tail pipe - failing to make an airtight connection.
Does it mean that the copper tail end connection from the taps are less than 15 mm in dia.
Can any one suggest how can make an airtight connection.
Joined: 12 Jul 2006 Posts: 277 Location: Hampshire, United Kingdom Thanked: 0 times
Posted: Tue Apr 24, 2007 7:09 pm Post Subject:
If the olive fits quite snuggly when slipped on, then it is 15mm, if it is simply not tightening up too well, then perhaps you have brass olives which tend to be a bit tougher. You can buy seperate copper ones which tighten up easier.
Posted: Thu Apr 26, 2007 7:57 pm Post Subject:
Kitchen mixer tap
The compression elbows which is a std 15mm from B&Q has copper olivers inside but they just easily slip onto the copper tail end.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
