Dishwasher Waste problem - not enough connections
25 Apr 2007
Glasgow
I have never done any plumbing before and have just bought a dishwasher thinking it would be easy to plumb in.
I dont think the supply will be a problem as i think a T will do the trick.
However, looking at the waste pipe connections above the P trap in my sink, there are 2 allready. The first is from the washing machine and the second is the overflow from the sink itself.
What is the best way to plumb in the waste from the dishwasher? Can i get a trap with 3 (spigots??) bits to connect a waste pipe to?
or should i make the sink overflow a junction...or ?
Any advice much appreciated.
Bilabong
Edit: Still not sure if this is the right forum... the plumbing "read before you post" says it should be here but..... sorry admin if its in the worng place.
Thanks for the reply. The one that is currently fitted looks like the one you recommened. The one i have has two hose attachments, and both are used.
Can you ge them with more than 2?
Many Thanks
Bilabong
If the waste pipe runs horizontally near the floor before exiting the kitchen, you can use a stand-pipe and bend arrangement, which to my mind is better, as it does not allow dirty sink water to flow into the washing machine under adverse conditions, and might be less prone to leaks and blockages.
Hi John,
The waste pipe runs horizontally out of the kithen about 1 and a half foot off the floor. There is only about 1ft of clearance between the worktop and the waste pipe. is that enough to work with?
The plumbing in my house looks a bit ropey... i just noticed that the sink drain pipe has been silicone sealed into the drain.
How high does a stand pipe need to be above the drain? (i will go and try and read up on this)
Bila
For clarity, i have tried to include a pic of the current layout
clf-gas said:
A wash machine trap John.
Ah... the correct name!
Have you got a pic?
Would it be a good solution?
I found two possibles for the problem:
The first one looks very similar to what i allready have but has only one hose attached:
The other one looks like what i thought a stand pipe arrangement should look like. One prob though, its 600mm high and i have only about 200mm from waste pipe to the bottom of the worktop.
Which one would you think is the best to deal with 3 waste pipes? (washing machine, dishwasher and sink overflow) or should i add the stand pipe for the dishwasher only?... im a bit confused so any advice or help would be much appreciated
Cheers
Bilabong
