DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
fixed one switch, broke anothe
This topic originated from the How to page called Replacing a one way light switch with a two way light switch
Click here to return to the page called Replacing a one way light switch with a two way light switch.
  View previous topic :: View next topic
Author Message
canter
from United Kingdom
Thanked: 0 times
PostPosted: Thu Apr 26, 2007 6:12 pm    Post Subject:
Reply with quote Thanks
Hi. Can anyone help.. I had a 2-way switch for my landing light which never worked properly - the downstairs switch worked on and off; the upstairs switch only worked when the downstairs switch was off. I have now fixed it so it works properly. But I have now got 2 problems: first, one of the bedroom lights no longer works so I assume it is next in the circuit. Any ideas how I should rewire it? Secondly, I discovered that the 2-way switch was installed with 3-core only. I think the earth wire might have been used for L1. Either way there is no earth earthed. Can it be made safe or should I remove the 2-way altogether. If so, would fixing the bedroom light be any different? Help much appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Thu Apr 26, 2007 6:23 pm    Post Subject:
you need to get a multimeter and completely map out what wires you have availible between what points.
Once you have a diagram post it and i'll try and work out the best soloution.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Thu Apr 26, 2007 6:25 pm    Post Subject:
By 3 core I take it you mean Twin and Earth? The earth (CPC) in twin and earth cable does not have an inner sheath, this should only ever be used as an earth and never as a live conductor.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Thu Apr 26, 2007 7:38 pm    Post Subject:
Yeah, your "3 core" is twin & earth & the bare wire must never be used as a live conductor.
It needs replacing with 3 core & earth ASAP.
The reason your bedroom light may not be working is if the feed to that switch comes off the two way you have disturbed. Maybe the wire is not in properly, at all or in the wrong place.
Does the bedroom light come on when the landing one is on?
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
canter
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 28, 2007 9:33 am    Post Subject:
Thanks - I thought as much - the earth wire is unsheathed and is definitely being used as live and I'll remove it. The bedroom light doesn't work at all whether the landing light is on or off. Will check the connections again to see if anything has been disturbed. If that doesn;t work, will try post a diagram - any other ideas about the bedroom light?
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Extra sockets and anothe fuse box 7 780 Mon Nov 29, 2004 1:42 pm
Bathroom extractor fan pull cord switch broke 5 820 Wed Jun 14, 2006 9:36 pm
HELP!!! Oven broke after flicking MCB switch to OFF 30 1420 Sun Jan 27, 2008 7:47 pm
Replacing 1 gang switch with 2 gang - now other rooms broke! 11 340 Sat Oct 24, 2009 10:51 am
Broke my megger 1552 lead 2 400 Tue Feb 05, 2008 10:08 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
