Zanussi ZDT6894 - No Water
29 Apr 2007
Middlesex
I have a similar problem which many have asked before but no one really has had a proper solution to the problem. My dishwasher was working ok for 2 years but now, no water is entering the machine. Like others, the inlet hose is not kinked and the machine drains ok. The machine makes the normal operating sounds and goes through the programme, but when you open the door there is no water? The filter on the supply hose is not blocked. The motor at the bottom under the tub-filter works ok and the machine drains prefectly. Can someone please help?
Machine thinks it's full of water already.
You've got a blockage in the pressure system somewhere.
Thanx for that.
Does that mean i need to call out an engineer? or is there any way i can check pressure system myself?
