DIYnot
Local | Network
   DIYnot > Forums
Local | Network
speaker cable
Goto page 1, 2  Next
Author Message
sarahproperty
from United Kingdom
PostPosted: Mon Apr 30, 2007 6:50 pm Reply with quote
can door bell wire be used instead of traditional two core speaker cable?
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 1058 times
PostPosted: Mon Apr 30, 2007 6:56 pm Reply with quote
For what?
Back to top
 Alert Moderators
sarahproperty
from United Kingdom
PostPosted: Mon Apr 30, 2007 6:59 pm Reply with quote
i have run out of speaker cable (the white two core stuff that is marked black along one of the cores) to do the surround sound for my dvd player and wondered if i could use door bell cable instead...
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 1058 times
PostPosted: Mon Apr 30, 2007 7:07 pm Reply with quote
It is probably best to continue using proper speaker wire. The doorbell stuff is a single solid conductor, and is of a smaller cross sectional area.
Back to top
 Alert Moderators
LondonRay
from United Kingdom
PostPosted: Tue May 01, 2007 11:40 am Reply with quote
It might 'work', but you'll suffer a SERIOUS loss of quality if you use bell wire, you owe it to your ears not to ! Especially if you've shelled out hard earned on a nice surround sound.
42 strand wire really is the minimum for any halfway decent system, 79 for preference. Also make 100% sure that the +/- (red/black) terminals are all consistently wired. Again, whilst it might work if they aren't it'll sound ropey to say the least.
Back to top
 Alert Moderators
Sam Gangee
from United Kingdom
Thanked: 225 times
PostPosted: Tue May 01, 2007 1:33 pm Reply with quote
The answer is "yes you can". It won't do any harm at all. For stereo, however, you must observe the polarity of the wires. I tie a knot in one of the pair and then trace that wire to the other end and tie another knot. I call that wire the "positive" wire and make sure that it connects to "+" or "red" at both ends.
I use bell wire for my speakers in the living room. Sounds perfectly OK to me. But I'm not one of those rich "golden eared" boys who can afford to waste 50 on a gold-plated oxygen-free bi-directional multistrand scart lead!
If you can afford that sort of stuff, try here:
http://www.glodark.co.uk/audio/unique.htm
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 923 times
PostPosted: Tue May 01, 2007 2:20 pm Reply with quote
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1467 times
PostPosted: Tue May 01, 2007 2:48 pm Reply with quote
Bell wire is a bit weedy.
I reckon 2-core 5A flex is OK and cheaper than crystalline oxygen free 200-strand magic speaker cables which I believe to be a trick to part the obsessive from his money.
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 303 times
PostPosted: Tue May 01, 2007 3:00 pm Reply with quote
Yep - bell wire is an absurd way of wiring any speakers!
If you don't want to fork out for mega money cable, use some 0.5 or 0.75mm flex.
Although TBH, the stuff you describe as "fig of 8 white stuff" is likely to be cheaper still than flex, and adequate for a small domestic install.
Bell wire - ITS FOR BELLS!
You have to remember that a speaker has a VERY LOW impedance, and adding un-nessecary resistance to the circuit will reduce the output hugely. Many amps also kick a fair amount of current at higher levels.....hello to bell wire overheating and failing.
Back to top
 Alert Moderators
Sam Gangee
from United Kingdom
Thanked: 225 times
PostPosted: Tue May 01, 2007 4:58 pm Reply with quote
Out of interest, how many Watts are the speakers rated at and how many Ohms? Answer in Watts RMS, please; not Watts "Peak Music Power" (which is meaningless). My speakers are rated at 10W RMS so bell wire is more than adequate. I calculated that the total resistance of 3m (doubled of course) is 0.25 Ohms. Not very significant for an 8 Ohm speaker.
In the end, the answer - if you've already got some bell wire - is to try it. As I mentioned previously, it won't do any harm. (It hasn't done my speakers or amp any harm. It hasn't melted the wire or insulation).
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 1058 times
PostPosted: Tue May 01, 2007 5:08 pm Reply with quote
Back to top
 Alert Moderators
keithpenny
from United Kingdom
PostPosted: Tue May 01, 2007 5:17 pm Reply with quote
very good answer!!!
places like richer sounds make a good percentage of their profit selling ridiculously expensive 'wires'!!!!
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 226 times
PostPosted: Tue May 01, 2007 7:39 pm Reply with quote
RF Lighting wrote:
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 460 times
PostPosted: Tue May 01, 2007 7:51 pm Reply with quote
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 923 times
Crafty wrote:
RF Lighting wrote:
Wow...... I know ampliers can melt wire but the energy from a speaker melting wire. No way.....
( if you speak into a speaker it may act like a moving coil microphone and produce a few milliwatts of electricity on its connections. )
Back to top
 Alert Moderators
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Ceiling speaker cable 16 1120 Tue Dec 14, 2010 11:25 pm
Power and speaker cable ok in same trunking? 10 260 Wed Apr 17, 2013 12:32 pm
attaching speaker cable to UPVC architrave 45 900 Fri Jul 18, 2014 5:39 pm
Speaker cable 18 1800 Fri Nov 12, 2004 4:57 am
House speaker 5.1 wiring / HDMI Cable help. 12 1380 Sat Jan 17, 2009 8:44 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
