DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Melted socket and plug
Author Message
richard_1234
from United Kingdom
PostPosted: Tue May 01, 2007 9:15 pm Reply with quote
Hi
I have a washing machine pluged into a socket inside my kitchen cupboard. The washer went wrong so we got a new one, on removing the old washer we found that the face of the socket behind the plug had melted and turned brown and the plastic around the pins of the plug had melted including the black bands (safety plug) allowing the pins to wiggle.
The socket looked perfectly normal until the plug was removed and could have been like it for months without realising.
Just wondering what caused this?
p.s. the socket has been replace and the wire behind was fine and the cause of the washer to go wrong was a faulty motor sensor.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1467 times
PostPosted: Tue May 01, 2007 9:20 pm Reply with quote
most likely a wire was not tightly gripped in its terminal. This creates a high-resistance joint which gets hot, as it gets hot it gets looser, so hotter, so looser. Eventually the junction between the wire and the terminal will burn away.
This most often happens with heavily loaded connections, such as the switches for electric showers. For some reason it more often happens with the black neutral wire.
The end of the wire that overheats is damaged by the heat and softened so that it will not form a good connection in future, so will overheat again. So the discoloured end needs to be cut off back to bright metal. Professional electricians have a tool to put a new end on if the wire is too short after cutting back (it needs great pressure to do it properly).
Was it a single socket, or a double?
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 226 times
PostPosted: Tue May 01, 2007 10:22 pm Reply with quote
another cause i've heard is the pins not being gripped tightly enough in their holes, creating a high-resistance connections between the plug and socket.
Also corrosion and muck on the pins.
Back to top
 Alert Moderators
DESL
from United Kingdom
PostPosted: Tue May 01, 2007 10:37 pm Reply with quote
Ah that's why in the old days appliances like washing M/Cs were wired into a fused outlet. I was told by an old time served sparky that fixed appliances should never be plugged in as the design of the 13A plug and sockets cleans the contacts as you unplug and plug in.
Cause of socket failure was put down to a certain amount of corrosion and weakening of the contacts which will eventually cause some minor arcing leading to a build up of carbon which then increases arcing and heat until one day they overheat to a point when thay fail.
But these days as soon as you cut the plug off to wire into an outlet you invalidate the appliance warranty
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 226 times
PostPosted: Tue May 01, 2007 10:52 pm Reply with quote
I took apart a 3-way adaptor block the other day. The pins are very brown, not shiny at all, because they haven't been inserted or extracted in so long.
And the socket contacts inside have a very small surface area, I wouldn't say they are rated for 13 amps. Again very brown and dull. Whenever a plug is inserted, it sparks because of the high resistance.
Its going in the bin, i've never liked 3 way blocks.
Back to top
 Alert Moderators
nozspark
from United Kingdom
Thanked: 34 times
PostPosted: Tue May 01, 2007 10:54 pm Reply with quote
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Plug melted in the socket! 9 260 Mon Feb 04, 2013 7:33 pm
Melted Plug 15 1120 Tue Jun 15, 2010 9:42 pm
melted plug fuse 11 1820 Mon May 14, 2007 10:38 am
What can cause a plug pin to look melted? 4 721 Sun Sep 28, 2008 1:27 am
Neutral pin on plug melted - what happened? 8 1520 Wed Jul 12, 2006 10:41 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
