Joined: 02 May 2007 Posts: 4 Location: London, United Kingdom Thanked: 0 times
Posted: Wed May 02, 2007 5:19 pm Post Subject:
Mouldy Wooden Window Frames
Mould has developed inside my wooden window frames and have an infestation of wood louse. The surveyor from my Housing Assocition blamed me not not controlling cendensation so they are refusing to change the frames
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Wed May 02, 2007 5:45 pm Post Subject:
If they were wet on the inside, condensation is most likely. If they were wet and rotted from the outside only, most likely would would be lack of maintenance in painting and puttying. This would show itself in all the other windows on that side of the block.
Posted: Wed May 02, 2007 5:53 pm Post Subject:
Age is not excessive, but if they are rotten they need replacing. It is sometimes possible to repair them. It may only be the opening sashes that need replacing. Woodlice only eat damp and rotting wood.
Joined: 03 Feb 2007 Posts: 33 Location: Leicester, United Kingdom Thanked: 0 times
Posted: Wed May 02, 2007 9:19 pm Post Subject:
Surely the housing environment is poor. If a tightly insulated ,modern house is expected not to have cndensation, where is the steam and vapour expected to go? Has it mechanical ventilation system- preferable heat recovery?
Ask the Housing Association to ask their architects about this, not you as a user. Get them to fit that.
This is pathetic. Windows used to last 60 years +.
Also they are probably using inferior materials in construction, tackle them on this too.
They always blame the user, but the designer has screwed it up
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
