Mark27
Joined: 04 May 2007 Posts: 2 Location: Plymouth, United Kingdom Thanked: 0 times
Posted: Fri May 04, 2007 9:17 am Post Subject: Intesit electric oven and gas hob – Wiring? |
I have recently purchased a new Intesit electric oven and gas hob and I am a little confused about the wiring?
The old cooker that I am replacing has it own direct connection to the consumer unit (with its own 30Amp fuse). There is cooker control unit that sits above the worktop and feeds down to some form of junction box behind the cooker. The cooker was connected directly to the junction box.
Can I replace the junction box with a double socket? (One plug for the cooker and one plug for the ignition switch on the hob)
Gas Hob ignition – 220-240V ~ 50-60Hz
Electric Oven – 230-240V ~ 50Hz (Maximum power absorbed 2250W – 2400W)
I would be grateful for any advice?? |
luminaire
Joined: 11 Jan 2007 Posts: 700 Location: United Kingdom Thanked: 0 times
Posted: Fri May 04, 2007 11:39 am Post Subject: |
Yes, that should be ok. Presumably the oven and ignition switch came with its own flex? |
jj4091
Joined: 01 Dec 2006 Posts: 1794 Location: Cumbria, United Kingdom Thanked: 8 times
Posted: Fri May 04, 2007 1:40 pm Post Subject: |
Personally I would change the 30A fuse for a 15A one. |
Mark27
Posted: Fri May 04, 2007 5:45 pm Post Subject: |
Yeah ignition switch came with its own flex.
Many Thanks, |
