DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Solar Panels and Water Features
Author Message
BigMatt
from United Kingdom
PostPosted: Fri May 04, 2007 11:46 am Reply with quote
Hi All
First post - after googling for an Electrical Forum.
We have a cascading water feature similar to this one (ours is a couple of years old) :
http://www.greenfingers.com/superstore/product.asp?dept_id=200345&pf_id=LS1143D
The solar panel that comes with it works well when the sun is directly on it but as the day moves on the sun goes to West and the fountain stops. What I was thinking was whether I could add a second panel in pointing to the West (the other panel is lieing on the shed roof facing South). Or is it the original panel of a "lower" spec so can't pick up in all directions.... and do I need to replace the panel?
Any suggestions greatfully received.....
Back to top
 Alert Moderators
jj4091
from United Kingdom
Thanked: 132 times
PostPosted: Fri May 04, 2007 1:37 pm Reply with quote
An easy way to test your panel would be to un-secure it & turn it into the sun & see if the pump starts up again, in which case you have your answer. It seems like an expensive solution to add another panel, but if you have no option then I would have thought you can simply connect it in parallel with the other one, providing it is of the same output spec. I would not have thought it would act as a load, but I am not 100% sure.
Back to top
 Alert Moderators
RobFurn
from United Kingdom
Thanked: 1 time
PostPosted: Fri May 04, 2007 1:47 pm Reply with quote
I wonder if a carefully positioned Mirror could deflect the sunlight back onto the pannel when the sun turns. May work for a short time. May also blind you neighbours though icon_lol.gif
Did you see that in news yesterday Now thats solar power:
http://news.bbc.co.uk/1/hi/sci/tech/6616651.stm?ls
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Water features and led lighting 6 400 Sat Jul 25, 2009 2:21 pm
CU features 6 2280 Thu Nov 03, 2005 3:14 pm
solar panels on the roof and what you'll get back 9 420 Thu May 19, 2011 8:35 pm
Fit 2 PV solar panels now, more later? 39 560 Thu Sep 22, 2011 3:47 pm
Why is my neighbour installing solar panels? 25 1020 Fri Dec 02, 2011 6:23 pm
DIYnot
